Fibre 65 not getting guaranteed speed
sajid
Whizz Kid
Message 37 of 37
Hi, so fibre 65 has just gone live today, was previously on fibre 35 achieving the full 40/10 download/upload.
But looking at the sync speed it's not near the guaranteed speed offered in my contract, I'm currently plugged into the the master socket and that's the nte5c mk4 master socket, no other sockets in the house.
Will a rep please be able to take a look at my speeds, I've switched the router off for 30 minutes to refresh the connection to the cabinet and I'm also using the latest wifi hub.
I'm not even hitting the guaranteed upload sync speed either.
Here is the email copy about my speeds;
You can look forward to an estimated download speed between 62.7Mb/s and 80.0Mb/s with a minimum guaranteed speed of 56.2Mb/s with a guaranteed upload speed of 20.0Mb/s.
36 REPLIES 36
Message 21 of 37
I'm using a tp link wifi extender, I'm having to reboot the extender when the channels get changed as the extender cannot cope with it, it doesn't recognise the channel change, I've gone back to my Huawei wifi hub black, It syncs at a slightly lower rate but the ping is also lower, and there is no wifi optimisation, it should be user accessible. I just find that the wifi hub black performs alot better than the sagemcom one.
Message 22 of 37
Only the Sagemcom routers use this feature, which is why older ones do not use it. If you could turn off remote management, you would never get WiFi Optimisation disabled, because it can only be done remotely.
You mention WiFi extenders, what make/model are these & how many do you have? I am simply trying to help you, if I can get evidence of what WiFi optimisation is doing wrong, then this will allow me to build up a case, to try to get you an exception.
sajid
Whizz Kid
Message 23 of 37
Right this is getting beyond a joke now, it's messing with my wifi extenders and it's causing havoc! Why isn't there an option to turn this thing off, this so called WiFi optimisation does not work this is why I set a manual channel because I've never had a problem before this! Even the older routers don't do this, the wifi has always been stable it is a simple option and it has been removed, is there even an option to turn off remote management on the wifi hub?
sajid
Whizz Kid
Message 24 of 37
Hi, I wasn't having this problem with wifi on my old router, I would set the channel manually and would never have to change I would get good signal strength and speeds on wifi, it's the wifi optimization that's causing issues as it randomly changes channels and causes the drop out because when I go into router settings to check the WiFi channel has been changed.
The broadband connection seems fine and the light is solid white when this happens.
Message 25 of 37
Hi @sajid
@Gliwmaeden2 has asked me to help you. It is correct that WiFi optimisation can't be turned off anymore. However, if I do an analysis of your WiFi network, then I may be able to resolve the issues that you have.
Message 26 of 37
All we can do is send feedback, like this, @sajid.
The devices people seem to prefer control this way to manage other factors which might also affect quality of service.
Message 27 of 37
That's a bit of a pain as the wifi keeps dropping when it changes channels automatically, not ideal, the user should have full control of their router each home set up and environment is different it's causing chaos, is there even a way to have it switched off?
Message 28 of 37
@sajid, staff can no longer switch off WiFi optimisation.
@KeithFrench may be able to offer guidance.
Message 29 of 37
Hi another request can you please turn off wifi optimization as it's changing wifi channels automatically even when I have preselected one's that work for me.
Message 30 of 37
A returns bag is on the way.
Message 31 of 37
Ok thanks for your help, I have a much older router that has been laying around and would like to send it back along with some microfilters, are you able to send me out a returns bag please?
Thank you
Message 32 of 37
Sync speed is at 55.4mb which is within the estimated range for your connection, so the speeds are now correct.
sajid
Whizz Kid
Message 33 of 37
Hello, I have received the router over the weekend and have tested, I made sure that when I swapped over the routers the connection got refreshed for 30 minutes, there has only been a slight 2-3mbps improvement are you able to look at my line please and then see if an engineer is required? Thank you.
Message 34 of 37
My Tests didn't show a bridge tap, but if things are the same with the new router, then there nay still be one present and an engineer would be required.
sajid
Whizz Kid
Message 35 of 37
Hi thanks for your reply, from what I remember last time there was a bridge tap present on the line, which was an external bridge tap, causing low speeds and instability, a new router didn't fix it, but will give it a try, I've also tested with a microfilter in the test socket and still haven't seen hadn't seen an improvement.
Message 36 of 37
Profile settings are correct, and tests are clear, but the speed is just below what it should be.
I'm going to get a new router to you, so we can rule out hardware and see if it will sync at a better rate.
If this fails then we will need to progress towards an engineer for you.
Anonymous User
