Fibre 65 speed problems
dollydee
Message 10 of 10
 Speed test on laptop
 Speed test on phone. Apart from smart tv, which was not switched on when I did tests, these are the only devices connected to Wi-Fi.
Have phoned technical support and also online chat. Each time they run tests they say the speeds are a lot faster. Have also done connection tests that say service could be improved and that it has been disconnecting. Don’t feel I’m making any progress. I have had HG 633 router for 8 years. Tests show it is working ok. I upgraded from fibre 35 to fibre 65 in March. Previous to this I didn’t have any problems and never felt the need to check speeds. I have not experienced any enhanced speed  since upgrading. Any suggestions?
9 REPLIES 9
Message 1 of 10
Message 2 of 10
Thank you! Much appreciate the help from the TalkTalk community and support team!
Message 3 of 10
Hi dollydee,
I've ordered the router and returns bag, it should be with you within a couple of days
Message 4 of 10
Thank you for your help! I have now had a message asking if I would like a new router to test if this is the problem. I hope this sorts it.
Message 5 of 10
Hi Michelle
Thank you for your reply.  Please can you arrange for a new router to be sent to test if this is the problem. I will return old router as requested.
Message 6 of 10
I'm sorry to hear this. I've run a test on the line now which is clear. Would you like us to send a replacement router for testing purposes to see how this compares? We would also send a router returns bag so that the original router can be returned.
Message 7 of 10
I'll move this to the ordinary Fibre message board, @dollydee, as this is not a Full Fibre installation but fibre to the cabinet.
Staff will reply during the day, @dollydee.
Sounds like you need a new router at least to test.
Message 8 of 10
last post should say 8mbps to phone. Download speed to router is 45mbps,
dollydee
Message 9 of 10
Download speed to laptop is 33mbps and to 8mbps,  Why would there be such a big difference from download speed to router?
