on 06-04-2024 10:26 AM
Hi All,
I have a problem with my HG635 router in that it keeps on resetting itself to factory defaults, which is rather annoying as I have to reset its IP address, DHCP server & port forwarding due to the continual resets. I also don't use the Talk Talk Wifi as I have an EERO mesh system, along with a lot of home automation (such as a Hive Thermostat, Hue Lighting, Govee Lighting etc.)
The modem was looking a software image file at one point.
Chrome Screenshot
Anyone else had this issue and if so how did you fix it?
on 08-04-2024 07:11 AM
Hi Davemjames
Apologies for the delay.
I've ordered a replacement router for you now, please allow 24-48hrs for this to arrive.
on 06-04-2024 01:13 PM
Ah OK I see. Well, I have asked them to replace it, they do not work at weekends, so it will still be Monday now.
on 06-04-2024 01:11 PM
Hi Keith,
I only have FTTC (Fibre to the cabinet) not FTTP (Fibre to the property), still have to use the old copper wires to connect.
on 06-04-2024 11:46 AM
This does not make sense, if you have the Eero, just connect it to the Ethernet cable from the ONT, you don't need the HG635 at all.
on 06-04-2024 11:44 AM
Hi Keith,
I have to use the router, I just don't use the WiFi provision from it.
Thanks for asking a Tech Support to exchange my router. I think it's coming to the end of it's life.
on 06-04-2024 11:22 AM
Sorry, on re-reading your post, if you do not use this router, then surely it is simply a case of returning it.
on 06-04-2024 11:16 AM
You cannot update the firmware yourself. Your router is old, I will ask TalkTalk to replace it for you.
