Inconsistent wi-fi
delypo
Message 127 of 127
I have had  the Huawei HG633 router for nearly 10 years. Whilst the fibre broaband speed coming into the house meets what Talk Talk guarantee, I experience WiFi inconsistency most days, with devices dropping connection, which requires frequent reboots of the old router to re-establish the WiFi connection.
I can see you offer a superior router to your new customers. As a customer of almost 18 years standing, could my old router please be upgraded? Thank you.
DP
126 REPLIES 126
Message 101 of 127
Hi @Debbie-TalkTalk @Anonymous @Chris-TalkTalk
This customer has a bigger house than some would really benefit from a Sagemcom FAST266 WiFi Booster to go with his 5364/5464 router. Would this be a possibility?
delypo
Message 102 of 127
Hello @KeithFrench
The router is situated at the front of the house, on its own cupboard shelf, in the lounge with no other electrical equipment in its immediate vicinity.
Moving from that room to the other two rooms mentioned there are no large expanses of metal nor any fish or water tanks.
Message 103 of 127
Hi @delypo
Your problem was easy to detect from those screenshots, but before recommending a solution, please can you tell me where the router is located. Is there any other electrical equipment near it. Enroute from there to the three rooms that you mention, are there are any large expanses of metal or any fish or water tanks in the way?
delypo
Message 104 of 127
That's good to know, thank you @KeithFrench and there's no rush - appreciate your help in this.
Message 105 of 127
Hi @delypo
I have them all now. It is really helpful that you have thought to get them from all three locations. I will try & look at them a bit later this afternoon.
delypo
Message 106 of 127
Good Morning
Screen shots have just been sent to @KeithFrench for analysis
Message 107 of 127
No problem @delypo
delypo
Message 108 of 127
Thank you @KeithFrench, will get back to you over the course of the next few days.
Message 109 of 127
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please they can be difficult to read as text can get out of focus when zoomed in, from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus.
delypo
Message 110 of 127
Hello @KeithFrench
Thank you for your response. The replacement router is the Sagem Wi-fi Hub 2 Fast 5464. This has been in situ from Fri 10th May and we have seen no intermittent drop outs and the light has remained a solid white. If we use the laptop wired, then it performs well at a speed of 67Mbps.
Any help you can give to try and improve our 2.4 GHz WiFi speed around the house would be appreciated and so we would be grateful to receive your guide and any support you can give. Thank you.
Message 111 of 127
Hi @delypo
@Anonymous has asked me to help you to try & improve your 2.4GHz Wi-Fi speeds. I assume that your replacement router is the Sagemcom FAST5364?
Message 112 of 127
Thanks for confirming. @KeithFrench - Would you be able to offer any advice on this please?
delypo
Message 113 of 127
No, they are older devices and will only connect at 2.4 GHz.
Message 114 of 127
Hi delypo
Thanks for your reply. I'm glad to hear that the connection has improved.
Can these devices not connect on 5ghz or will they only connect at 2ghz?
delypo
Message 115 of 127
Hello Debbie
We have seen an improvement with the new router.
A more stable WiFi connection has been witnessed (notably our CCTV playback is constant, compared to several gaps we were seeing with the old router) and we have not noticed any drop outs.
We have moved two mobile phones and a Tablet onto the 5GHz Wi-fi frequency and get consistently good speeds of 60-67Mbps on these devices in every room of the house.
However whilst speeds on devices using  the 2.4GHz frequency are better than they were, they still vary from room to room (between 20 and 50 Mbps -  most often on the mid-low end of this range). Unfortunately, our laptop is not dual band and is used in an office-come-conservatory at the back of the house (router is situated on the same level but at the front of the home). Similarly devices on the 2.4 GHz frequency situated in the back bedrooms also produce slower speeds.
So, whilst things are better on the whole, do you have any further suggestions that may improve speeds on those devices restricted to 2.4 GHz?
Message 116 of 127
Hi delypo
How's the connection been over the weekend?
Message 117 of 127
Hi @delypo
That's great 🙂
I will check in again with you on Tuesday to see how the connection has been over the weekend.
Message 118 of 127
delypo
Message 119 of 127
Hi Debbie, the new router has just arrived. I will set it up at the weekend and will provide some feedback in a week or so to give me time to test it and to compare its  performance to that of the old router.
Message 120 of 127
Hi delypo
That's great, thanks for letting me know 🙂
