Internet connection disconnecting and intermittent crackling on phone
johnny95
Whizz Kid
Message 123 of 123
My internet connection has been disconnecting for serval months. Recently it has got worse. I also have intermittent crackling on the phone. I was using the black Huawei hub and then the Sagemcom WiFi hub 2.
However they both were rebooting automatically. So I then tried a different setup with a router and modem. I used the BT Huawei Echolife HG612 provided by Talktalk a while ago, and a Eero Pro 6 router. The DSL on the modem did the same and kept dropping. I'm now using a Draytek Vigor 166 modem with the Eero Pro 6. Unfortunately this modem also dropped DSL. So it's fair to say it's the internet connection where the problem is.
I have now connected my modem to the test socket on the master socket. It's been connected for just over a week. As far as I know it hasn't dropped so far. I'm thinking it may be the faceplate on the socket that could be the problem? However I'm not 100% sure. It could be a line or exchange issue? I had an issue with the exchange over 10 years ago, where the filters needed replacing. Maybe it's the same issue, I'm not sure.
As there has been so many disconnections my speed has dropped from 58Mbps to 44Mbps. I'm guessing the DLM has slowed it down?
Please can you help,
Cheers,
John
122 REPLIES 122
Message 121 of 123
Ok so I should take everything out? As I say the faceplate is already out.
Message 122 of 123
Hi @johnny95
The line test has detected a loop fault and this is often caused by internal wiring or equipment connected to the line.
Would it be possible to remove everything from the line including the face plate for 15 minutes so I can run another line test in this set up?
