Internet keeps disconnecting ..
on 28-02-2024 03:22 PM
Message 32 of 32
Since November 2023 the Internet has been disconnecting once or twice daily. Each time I have reported a fault but I've been given a fault number and the Internet has reappeared. A text and an email says If I still have problems, to open a chat with support. Nobody on chat has been interested if the Internet has come back.
The last fault was reported on 25/02/24 number REP-14032492. This report has prevented me reporting this morning's debacle when the Internet has failed at 10:30am, 11:14am and at 2:40pm. Because there is a fault report outstanding I can't seem to get to a chat to discuss the current issue. Typically, the white light stays lit on the router and my ping app says that Talktalk's IP address is different when the Internet starts working again.
I would like to know how bad these problems have to be before Talktalk will accept that their service isn't working and release me from my 2 contracts and let me install a 5G connection with a dish in search of improved reliability. Of course it would be better if things went back to pre-November '23 days.
Our setup at home hasn't changed for 2 years, with a Talktalk DG8041 router. Can anyone help, please?
hawaye
Mornington Crecent County Champion 1975, 1976, 1978
Labels:
- Labels:
Connection
Stability
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
31 REPLIES 31
on 29-02-2024 09:46 AM
Message 21 of 32
Chris, yes I have 2 numbers in houses on the same street. The main number ends 9064 and the second number ends 9964. The second number tested OK on 17070 a few minutes ago with no noise on the line.
I am monitoring 9064 with a Windows laptop pinging 8.8.8.8 continuously.
hawaye
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 29-02-2024 09:17 AM
Message 22 of 32
Thanks for trying that. What do you mean by "second number", do you have two lines?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 29-02-2024 08:57 AM
Message 23 of 32
Thanks Chris. I've just dialled 17070 and it reports the right number. I will have a chance to check my second number later this morning.
I'm using an app called Pingtools. On the 5:30 disconnection, it reported that I reconnected to Three, not TalkTalk. Do you have a relationship with Three?
Pingtools also shows the IP address I'm connected to. Every time my Internet reconnects, a different IP address shows, but all so far begin 92.
Hope this helps but I'm very concerned that your system doesn't show the nuisance I'm experiencing.
hawaye
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 29-02-2024 08:08 AM
Message 24 of 32
Hi Joe902,
If you need assistance can you please start your own thread/topic if you haven't already, and we'll be happy to help
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 29-02-2024 08:07 AM
Message 25 of 32
Hi hawaye,
There are no disconnection or unavailable seconds showing yesterday at all. Could you dial 17070 from your TalkTalk landline and confirm that the number read back to you is your. I just want to make sure that you don't have a crossed line
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 29-02-2024 01:36 AM
Message 26 of 32
Hi, same here for months and days, same here about a test socket for the router which is not possible on a master socket 5c it has a built in filter.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-02-2024 04:58 PM
Message 27 of 32
And, annoyingly, today 4:40 pm. Router went to orange light; normal dial tone on phone.
hawaye
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-02-2024 04:09 PM
Message 28 of 32
I'm surprised you can't see the disconnections today and on the 25th which appeared to trigger the router update. There have been a dozen disconnections in the past fortnight. Typically the router light stays white but has gone to flashing orange a few times when disconnected.
hawaye
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-02-2024 04:01 PM
Message 29 of 32
OK thanks. Line test is passing and sync looks fine and there are only 2 disconnections showing in the last couple of weeks (26th and 27th). Have you noticed if the light changes on your router when the connection appears to drop?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-02-2024 03:51 PM
Message 30 of 32
Hi Chris, thanks for the reply. The router is connected to the Openreach socket. I'll add that the router was updated on 25/02/2024 but it hasn't made any difference. The telephone has no problems although I can't say if that's true when the Internet is down. I was advised to run ping -t which happened to be running this morning; it said timeout, then general failure when the Internet stopped this morning.
hawaye
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-02-2024 03:37 PM
Message 31 of 32
Hi hawaye,
I'm sorry to hear that you're experiencing problems with your service. Could I just ask, is your router currently connected to the test socket? Are you experiencing any problems with your telephone service?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- « Previous
- 1
- 2
- Next »
Related Content
- TalkTalk are unfit to run broadband services in the UK in Fibre
- AVOID TALKTALK: TalkTalk cancelling my transfer to a different broadband provider in Billing
- Slow on ethernet in Full Fibre
- Broadband connection in Broadband
- Talktalk disconnected a vulnerable persons internet due to system cancellation in Broadband
