on 11-12-2024 02:11 PM
Hi all,
First post here so I hope I’m doing this right. I’ve been a TalkTalk customer for the last few years and have had no issues up until very recently. I have had an air source heat pump installed and alongside it, a Vaillant VR940f WiFi gateway.
For whatever reason, the gateway just absolutley refuses to “play ball” properly. Sometimes it works, sometimes it doesn’t. I’ve tried just about every solution I can find online and am fairly confident that the problem is this router, a Huawei DG8041W.
I’ve found some posts on here which would suggest this router is actually discontinued and that TalkTalk should replace it, but when I phoned and tried to get support, the call was seemingly going to take all day and I didn’t have the time, they weren’t interested in simply replacing the router and didn’t seem to understand my issue so I gave up.
Can anyone here from TalkTalk help?
Thanks in advance!
on 11-12-2024 02:31 PM
I'll get a new router out to you and see if this helps.
