More help for customers that don't own a mobile phone.
Mr_Nutz
Message 19 of 19
I needed an engineer to come and look at my connection (only getting 29-30mbps) but because
I don't own a Mobile this is not possible. Are none mobile users now second class customers?
18 REPLIES 18
Message 1 of 19
Hi Mr_Nutz,
Thanks for trying this. Just to confirm, do you have an alternative router that you can test with?
Message 2 of 19
Message 3 of 19
Hi Mr_Nutz
Thank you. We can then check the connection stats/speed again.
Message 4 of 19
Done @ 10:30 will get back to you in 48 hrs
Message 5 of 19
Hi Mr_Nutz
If DLM detects that the connection is unstable then it will change the profile and reduce the speed to stabilise the connection.
Please can you connect the router directly at the test socket for 48hrs without rebooting the router. We can then check to see if DLM increases the sync speed.
Message 6 of 19
Also I only have a wired conection cat6 1.0gbps network.
Message 7 of 19
I was getting 38 and yes I have rebooted the Router.
Message 8 of 19
Message 9 of 19
Hi Mr_Nutz
I've completed a line test which hasn't detected any faults and your line is in sync at 33mb.
What speed were you previously receiving?
I can see re connections on the line and this can affect the sync speed. Is the connection dropping or has the router been rebooted?
Message 10 of 19
@Mr_Nutz nothing showing might have missed it off
remember no personal info in the screen shots or on posts
Hope that help Regards Joe
Message 11 of 19
Updated my profile and here is a screenshot from this morning.
Message 12 of 19
Hi Mr_Nutz,
Please can you update your forum profile to include your telephone number so that we can look into this further. To do this go into "my settings" then "personal information" then add your details.
Please do not post any personal information on the forum.
hosay299
Message 13 of 19
@Mr_Nutz  What router do u ahve and how are u set upo and doing the speed test and
what is the speed showing on ur router page
Message 14 of 19
   Yes still not getting the speed I'm supposed to get only 32mbps not what I used to get.
Message 15 of 19
Hi Mr_Nutz,
I'm sorry to hear this. We usually ask for an alternative contact number when logging a fault and if you don't have a mobile number then a landline number would be fine. The only exception to this would be if the landline was experiencing the fault.
Are you still experiencing issues with the broadband connection at the moment? Would you like us to look into this for you?
Message 16 of 19
That's not what I asked. 🙂 But why not avail yourself of the support on the community by posting in the appropriate help section?
Mr_Nutz
Message 17 of 19
My landline is working fine and we do have a postal service in the UK.
Message 18 of 19
If you have any suggestions as how otherwise to contact customers whose phone and broadband service is not working then feel free.
