Persistent line faults
Teric
Message 26 of 26
Since January 16th I have had 10 line faults. I have gone through the usual:-
Plug in to openereach socket.
Do a factory reset on router.
Disconnect everything except for PC.
Despite all of this I still get my TV saying 'no signal' at times and my phone cutting out at times.
The we are fixing your fault message appears for a couple of days and I then get a message to say that it is fixed. In the meantime my broadband is either side of the minimum guaranteed which is 35 as I have fibre 65. Occasionally it climbs to 50 without me doing anything.
Can anybody suggest how to restore my service?
Teric
Long suffering TT customer
25 REPLIES 25
Message 21 of 26
Morning Michelle, thanks for getting back to me. I do have an old Plusnet router I will change it over and get back to you.
Thanks    Eric
Message 22 of 26
I'm sorry to hear this and I will take a look now. I've run a test on the line which hasn't detected a fault, however I can see a few re-connections and the sync speed has dropped. Thanks for confirming that the router is connected to the test socket (behind the faceplate). Have you ever tested with a different router to rule this out?
Message 23 of 26
Thanks @Teric that should help the team immensely.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
Teric
Message 24 of 26
Teric.
Thanks for your post, in answer to your questions the router is a Huawei DG8041W and it is left on permanently.
Divsec
Message 25 of 26
Hi @Teric firstly, your post has been escalated and you should hear tomorrow. Couple of thoughts till the pros reach you.
Which router do you have?
When not misbehaving is it left permanently connected and powered on.?
Good luck in getting sorted, I'm sure you will.
