Router is failing, speed keeps dropping.
raybell
Message 14 of 14
I have been having problems with my router for a while but they have got worse recently. Speeds are initially OK (50Mbps down 12mbps up) on a wired connection after a power down of the router but drop steadily over a few days. The only thing which brings the speed back to your guaranteed level is a long power down of the router, more than 10 minutes seems to be required..
This previously restored the speed for a few days but last time (yesterday) the speed started to drop almost immediately and was down to 10Mbps down 12Mbps up on the wired connection and even slower over wifi after just a day. Speed tests are done using your own speed test. The router is an HG633 which I have had since I first got a fibre connection from TalkTalk in 2017. I would therefore like to request you to send me a replacement router ASAP as the fault on this one is getting steadily worse.
Ray
13 REPLIES 13
Message 1 of 14
returns bag on the way, you only need to return the router, you can hold onto the cables and filter.
Message 2 of 14
Sorry Power supply is the old one it is just the cables and microfilter which are new and unused.
Ray
raybell
Message 3 of 14
No I can't see a returns bag or label in the box for the  new router. I've had the old router for 5 years so the original packaging is long gone!
So please send a returns bag and label.
Do you want all the accessories too? power supply microfilter and cables.. These would be the ones which came with the new router as I left all the old cabling in place.
Ray
Ray
Message 4 of 14
Hi raybell,
Do you have a returns bag in the box, if not I can send one.
Karrl
Gliwmaeden2
Message 5 of 14
Check for a prepaid label and bag in the box that came with either router and if there's none, staff can send you the returns bag, @raybell.
raybell
Message 6 of 14
OK
Will you send me a pre-paid label or will I need to pay postage?
Ray
Message 7 of 14
If you can return the old router, that would be great.
raybell
Message 8 of 14
Hi Karl and Debbie
The speed of the new router is holding up well, no significant systematic drop in nearly a week so I think we can confirm that the problem I had before was indeed due to the old router failing. Do you want me to return the old router or shall I recycle it locally?
Ray
Ray
Message 9 of 14
Hi Ray
That's great news. How's the connection been since your last post?
raybell
Message 10 of 14
Hi Karl
The replacement router arrived today and is now set up and working fine. Download speeds are somewhat faster than the old one especially over wifi to my laptop. I'll keep checking for a few days and see how it goes.
Ray
Ray
Message 11 of 14
You're Welcome 🙂
raybell
Message 12 of 14
Thanks for the quick response Karl, I'll post again to let you know how it goes.
Ray
Message 13 of 14
Hi Ray
I've a new router on the way to you, to see if this helps.
