Router lights
Paul661
Whizz Kid
Message 5 of 5
Router working but no lights showing
PaulH
4 REPLIES 4
Message 1 of 5
Sometimes the lights can be dim or a poor LED, does your internet and wifi work correctly ?
Paul661
Whizz Kid
Message 2 of 5
Huawi 8041w
PaulH
Message 3 of 5
Hi Paul,
Which router are you currently using please? (make and model)
Gliwmaeden2
Message 4 of 5
Sometimes the light does seem to fail, @Paul661.
You haven't mentioned which router model you actually have.
For example, the hubs have a control which allow you to switch the light off if it is too annoying,  or back on again, but of course that applies only if it hasn't actually failed:
https://community.talktalk.co.uk/t5/Articles/Wi-Fi-Hub-light-too-bright/ta-p/2460164
Staff won't be back before Monday.
Thankfully you appear to be getting online OK meanwhile.
Clarify which model it is and look out for their reply during the week.
