Speeds lower than I paid for
Canofworms
Message 3 of 3
Just done a speed check and it says you are getting the 12 mbs fibre
but here’s the rub I paid for minimum 24 mbs in my contract
what do I do now when they say it’s what I’m on but I have it in black n white email
Message 1 of 3
Hi Canofworms,
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 3
2. What package are you on?
3. If you log into the router, what speed does this show (often in the initial dashboard area)? This is the guaranteed speed.
4. If you have any wired connections, are they affected in the same way as wireless ones?
