TV won’t connect to internet
TelfordEagle
Message 8 of 8
The internet connection on my box has dropped off.  I have tried reconnecting but it fails to connect each time.  The problem doesn’t appear to the internet itself as other devices are still connected.  What can I do to get connected?
7 REPLIES 7
Message 1 of 8
No Problem 🙂
TelfordEagle
Message 2 of 8
Thanks, that has resolved the issue.
Message 3 of 8
It does sound like a router issue, reboot the router and retest and see if it will connect.
TelfordEagle
Message 4 of 8
Looking at the router, the TV light is not lit.  Not sure if it usually is, but could this be part of the problem?
TelfordEagle
Message 5 of 8
There was an error code when it disconnected but unfortunately I didn’t make a note of it.  Now it just says Wi-Fi connection failed when I try to reconnect.
It is a 4k box connected via wi-if.  I have turned the box off at the mains but not rebooted the router; reluctant to do that in case it affects anything else.
Message 6 of 8
Any error messages or error codes on screen ?
Message 7 of 8
Which box do you have?
How is the box connected? Wired or WiFi?
Have you tried turning the box off at the mains and also rebooting the router?
