TalkTalk TV 4K Box - Software Update Fails
nickstride
Message 4 of 4
Software upgrade from 8.4.27-58 to 8.5.01-13 shows file downloading for over 1 hour then failing with message "upgrade file installation error 1829"
Please advise
3 REPLIES 3
nickstride
Message 1 of 4
Thanks to Karl and fr8ys for advice to factory reset the 4K TV box. Took the added precaution to reset the router to force a change of IP addressor. Update completed successfully with no dramas in ~12mins. Many thanks, Nick
Message 2 of 4
Hi nickstride
Did the reset help ?
Message 3 of 4
If turning the box off at the mains and on again does not resolve this, then a factory reset should.
Try pressing the button on the left hand side of the box 5 times whilst on and the box will restart and should download and install as part of the set up procedure.
Let us know how you get on.
