TalkTalk Wi-Fi Hub version SG4K100174
UsernameNotAvailable
Message 14 of 14
For maybe 7 or 8 months now various posts all saying same thing, when you log into the router and try to get into advanced settings you get logged straight back out. Despite clearing cache, using desktop or laptop or iPad, whatever you do it still kicks you out before you can change anything. Still no fix after all this time yet all caused by a forced firmware update that you cannot roll back. Come on TalkTalk, provide the old firmware or fix it, but this level of service isn’t acceptable, especially since you broke it in the first place by not testing it thoroughly before forcing it upon paying customers….
13 REPLIES 13
Message 1 of 14
Thanks for letting us know 🙂
Please can you keep the new router and return the old one using the returns bag.
Message 2 of 14
OK so original router was FAST5364-3.T8 and replacement is FAST5464-2.T4, both are running SG4K100174.
Prior to October/
November when firmware on old router was running fine and then it was quietly replaced which bricked it, basically it then took forever for router menus to appear (as in minutes not seconds) and then finally it would log you out, this replacement has been considerably quicker in the menus, though there is still a delay of a few seconds after any selection whilst it decides what to do, but it has so far remained logged in. Nothing else has been changed in the setup beside the router itself, same cables, same devices, same browsers etc. In fact the internet in general seems more responsive this evening with the replacement. So whatever the winter update did it basically knackered the old router.
There's a bag inside the box to return the router, so I might as well do it now because even if the new one develops a fault, it's already performing better than the old one. Obviously something to do with hardware because software appears to be same version. Hopefully there will be no further issues but definitely TalkTalk should either stop pushing silent unrequested updates, or at least offer the ability to download previous firmware to rollback. After all, if it aint broke don't fix it.
Message 3 of 14
Ok thanks for the update. Hopefully it will arrive today.
Message 4 of 14
Not as yet received
Message 5 of 14
Good morning,
How are you getting on, has the replacement router arrived?
Message 6 of 14
Thank you 🙂
Message 7 of 14
✔️ done
Message 8 of 14
Can you also add your TalkTalk account number to your Community Profile, I'm unable to locate the details with the landline number.
I can then send out the replacement router.
Message 9 of 14
Yes please
Message 10 of 14
Would you like me to send a router for testing?
Message 11 of 14
From what I've seen, it would probably be best being v4 router as this is a v3 which others have reported same fault even after exchanging to another v3
Message 12 of 14
I think we should send a replacement router for testing purposes to see if is still happening and to rule this out. Would this be ok?
Message 13 of 14
This has so far only affected a couple of customers, I have never been able to replicate it on mine.
