Very poor line performance (again)
cjedonline
Message 17 of 17
Hi, could you reset my line back to a reasonable speed please. Over the last few months (since July) it's been getting slower and slower. It's now way below my "Guaranteed" Speed.
Here's the current DSL status from my router :
Line Statistics
                                    Downstream          Upstream
Actual Rate              30000 Kbps            11999 Kbps
Attainable Rate       57916 Kbps              22708 Kbps
Path Mode                Fast                           Fast
Interleave Depth     1                                  1
Actual PSD               7. 7 dB                       11. 2 dB
                                    Near End                  Far End
Trellis                         ON                              ON
Bitswap                    ON                              OFF
ReTx                           0                                  1
SNR Margin             13 dB                          16 dB
Attenuation             19 dB                          26 dB
Here's the corresponding figures from July :
Line Statistics
                                   Downstream          Upstream
Actual Rate             53430 Kbps             19269 Kbps
Attainable Rate      59426 Kbps             19270 Kbps
Path Mode              Fast                            Fast
Actual PSD              7. 6 dB                       12. 4 dB
                                   Near End                  Far End
Trellis                        ON                              ON
Bitswap                   ON                               ON
ReTx                          0                                   1
SNR Margin            7 dB                            6 dB
16 REPLIES 16
Message 1 of 17
I'm glad to hear this and please let us know if you need any assistance 🙂
cjedonline
Message 2 of 17
Hi Michelle, it's still good :-
Line Statistics
 Downstream            Upstream
Actual Rate54997Kbps19251Kbps
Attainable Rate59443Kbps19251Kbps
Thanks again for your help.
Message 3 of 17
How has your connection been over the last 48hrs?
Message 4 of 17
Good morning,
I'm glad to hear this and we'll check back in with you in a couple of days just to ensure that the connection has remained consistent.
cjedonline
Message 5 of 17
OK, following Openreach doing something this afternoon, the line is back to "Normal" performance :
Line Statistics
 Downstream            Upstream
Actual Rate53998Kbps19985Kbps
Attainable Rate59232Kbps19985Kbps
Thanks for sorting this out.
Message 6 of 17
As this is a non appointed engineer, should be within the next 24hrs.
Message 7 of 17
Thanks, any idea when that might be ?
Message 8 of 17
One of our line tests is failing and showing a possible issue with the copper section of the line.
I've logged this out to Openreach to take a look.
Message 9 of 17
Yes, that's correct. I have tried it previously (with no change in connection speed), but it's quite inconvenient to have the router connected there (it's on an outside wall), so normally it's on an Openreach installed socket the other side of the room.
Message 10 of 17
Hi @cjedonline
Have you just moved to the test socket? (today)
Message 11 of 17
Yup, connected to test socket - improved slightly :
Line Statistics
 Downstream            Upstream
Actual Rate30000Kbps11999Kbps
Attainable Rate57979Kbps19977Kbps
Message 12 of 17
Hi @cjedonline
I've completed a line test and this is detecting a potential fault.
Is the router currently connected at test socket? Once I've confirmed this then I can raise this over to Openreach to be investigated.
Message 13 of 17
Hi Debbie, I turned the router off for 4 hours or so on Saturday. It made no difference.
However, this morning things are even worse!
                                   Downstream          Upstream
Actual Rate             20690 Kbps            11999 Kbps
Attainable Rate     43325 Kbps              19519 Kbps
Message 14 of 17
Hi @cjedonline
Apologies for the delay.
How's the connection been since the 30 minute power down of the router?
cjedonline
Message 15 of 17
No, there's no noticeable noise on the voice line (although it doesn't get much use) . I'll try switching off the router for 30 minutes, but in my experience, line training only works in one direction, a reduction of speed.
Message 16 of 17
It looks like noise on the line has increased and DLM has adjusted your connection downwards accordingly. Have you noticed any issues with your voice service? Have you tried switching the router off for a full 30 minutes to reset the session? And tried connecting at the test socket?
Subject to that, the support team will pick this up when they are back online from Monday.
