05-06-2024 07:32 AM - edited 05-06-2024 07:42 AM
I have downloaded the app and tried to set up VoIP to use my mobile phone for receiving home phone calls. But I get an error message in my account and no response to resseting the password in the app. I read in my computer magazine that talktalk hasn't enabled the system yet. If I contact the help desk they do not listen and want to run tests even though I stress there is nothing wrong with my broadband or eero router they are working ok. Help
I should also stress the phone adapter is also working ok and I can make and receive calls to the home phone.
on 07-06-2024 12:05 PM
The only other option would be to uninstall the app then re-install it
on 05-06-2024 08:11 AM
Hi bill,
Thanks for trying this. I'll ask my colleague Arne to take a look at this for you.
on 05-06-2024 08:01 AM
I have just tried chrome . Same result technical problems try again later
on 05-06-2024 07:54 AM
I use firefox to access my account is that the problem?
on 05-06-2024 07:45 AM
Thanks for confirming. Have you also tried using a different browser?
on 05-06-2024 07:44 AM
Yes it comes up with error try again later
on 05-06-2024 07:36 AM
Hi bill,
I'm sorry to hear this. Just to confirm, will it not let you activate it in your My Account? Do you receive any error messages?
