WIFI randomly disconnecting on devices
jimirvineuk
Message 16 of 16
Hello.
For the last couple of months, devices connected via wifi to our TalkTalk Wifi-Hub are disconnecting randomly.  You have to either disable wifi and then enable it again, or it comes back on its own after a minute. Other wifi devices still work at the same time when this happens, and the router white light is still on when this happens.
We have tried rebooting the router and this possibly helps, but not for long.
When I run a test it says there are no problems on the line.
Is this a router issue?
15 REPLIES 15
Message 1 of 16
Not all devices will identify themselves, some will only supply their mac address.  Had a device of my own, was driving me crazy for a couple of weeks trying to identify it, it turned out to be a mobvoi smart watch...... guessing it was not smart enough to identify itself.
jimirvineuk
Message 2 of 16
Hi. See on talktalk/devices that I have 13 devices working as expected and 4 devices with issues. 3 of their names are unknown so I will have to try and work out what which ones they are.
Message 3 of 16
Glad the connection has improved.  I'm only showing 7 devices connected currently so all looks ok here.
jimirvineuk
Message 4 of 16
The majority opinion is that there has been an improvement with the new router. It isn’t perfect but better. Can you see if we have an above normal amount of connected devices? Thanks
Message 5 of 16
Hi jimirvineuk
How are you getting on, how's the connection been?
Message 6 of 16
Good afternoon,
Great, thank you for the update and we'll check back in with you next week to see how you're getting on.
jimirvineuk
Message 7 of 16
It has now been delivered. I have replaced the old router with the new router and cables, and it is connected and working. I will see if it has a more stable connection for the wifi devices over the coming week.
Thanks!
Message 8 of 16
Hi jimirvineuk
Ahh ok, thank you for letting me know 🙂
jimirvineuk
Message 9 of 16
Not yet. It is due to be delivered today.
Message 10 of 16
Message 11 of 16
jimirvineuk
Message 12 of 16
Thank you. I will do.
Message 13 of 16
HI jimirvineuk
jimirvineuk
Message 14 of 16
Hi Debbie. If you think it could help, yes please. Thanks.
Message 15 of 16
Hi jimirvineuk
I think we should send a replacement router for testing, would you like me to arrange this?
