Wifi Channel keeps changing
s9bsk
Message 4 of 4
I'm trying to stop the router from automatically changing the channels on both 2.4ghz and 5ghz bands. I called customer service but they had no clue what I was talking about. 2.4ghz keeps choosing more congested channel 6 but needs to be on channel 11.
I've read WIFI Optimisation is the main cause of this, so can it be switched off, please?
3 REPLIES 3
Message 1 of 4
5Ghz will give faster speeds/  You can separate the wifi channels if you only want to remain connected to 5Ghz.
s9bsk
Message 2 of 4
When connected on the 2.4ghz band, my speed only reaches 33mbps download but when on 5ghz it reaches 63mbps. I tried this with no other devices connected and tested on different devices too. What could be the problem?
Message 3 of 4
Hi s9bsk
Apologies for this.
The WIFI optimisation has now been switched off.
