Xbox Showing Moderate Nat/Unable to acquire Nat Teredo Error
DanMay94
Message 25 of 25
Hi all,
Hoping somebody can help. I have had a talktalk fast router for a week now and have so far been unable to game on my Xbox series x. I either get an error stating a NAT type cannot be acquired, or I get a moderate NAT temporarily until it goes back to ‘unable to acquire’. I know a little about networking so I have tried manually port forwarding the Xbox ports etc however I can only seem to get the Xbox to get an open NAT for 5-10 minutes. I have read in a few other posts UPnP seems to be bugged on the latest firmware for this router which the Xbox requires to work. If this is the case, the router really isn’t fit for purpose. I tried calling talktalks technical support, and I must say they weren’t very helpful at all.
Any help would be much appreciated!
24 REPLIES 24
DanMay94
Message 21 of 25
Hi Debbie,
It would seem odd to need to factory the reset the router after only a week, but I will give it a go tonight and see how it goes.
If that doesn’t work what options do we have?
Thanks for your quick replies!
Message 22 of 25
Hi DanMay94
I don't believe this is an issue with the router. I've just checked with my colleague who uses the Xbox with the same router.
Could you try the factory reset to see if it helps?
DanMay94
Message 23 of 25
Hi Debbie,
I have only had the router a week so no I haven’t performed a factory reset yet, although I can try.
I believe it’s the Fast 5364 router I have.
 Can you confirm if the UPnP feature works correctly on this router with the current firmware? As I say, I have seen posts which say this isn’t the case.
I have updated my profile.
Many thanks!
Message 24 of 25
HI DanMay94
Have you tried factory resetting the router using the pin hole reset for ten seconds?
Which router do you have? (make and model)
Please can you update your Community Profile to include your name and TalkTalk landline number.
