broadband speed
daiw01
Message 13 of 13
I have experienced varying broadband speeds for a while now.  Currently with your speed test facility it is running at 66Mb.  A few days ago it was running at 32Mb.  I have unplugged and re plugged my connections in the past and nothing changed. The only times there has been a change is when the hub is switched of and then on again.  My hub is a HUAWEI  HG633, which I have had for about 7 years. Is it out of date as I am on the Fibre Broadband package?  It is most noticeable when using my Smart TV on iPlayer for example.  I get the spinning circle displayed for several seconds before the program restarts.  Windows 10 says my connection is unsafe. Is that a clue.
Your help would be greatly appreciated.
12 REPLIES 12
Message 1 of 13
Message 2 of 13
Hi Debbie,
I have posted my old router via the Post Office. Many thanks again
David
Message 3 of 13
Morning David @daiw01
That's great news, I'm so glad to hear that the speed/connection has improved with the new router 🙂
I've sent you a Private Message with a link to a short survey for the Community.
Thanks again.
daiw01
Message 4 of 13
Hello Debbie,
I am more than happy with my new router.  I have kept a record of the speeds over the last month since installing it.
They vary from 60Mb to 71Mbs anywhere in my house.  I have never had speeds like that before.  I have also not had to
switch it off and back on again since installation.
Thank you very much for your help.
I will be returning my old router via the post office in the next village. Ours was closed several years ago!!Best Wishes
David
Message 5 of 13
Hi @daiw01
How's the connection/speed been since your last post?
Message 6 of 13
Message 7 of 13
Will do.
Message 8 of 13
Hi @daiw01
That's great 🙂
Yes please let us know here how the connection is over the next month.
daiw01
Message 9 of 13
Many thanks Michelle.
New router arrived this morning. Installed OK and Wi-Fi is running at 67Mb.  The unsafe Wi Fi network message has also been fixed!
I'll check the speed on a daily basis and let you know the results in a month's time.  Does that sound like a plan?
Message 10 of 13
No problem. The router is on the way and should arrive in the next 48-72hrs.
Message 11 of 13
Have I replied to you?   I thought I had, but cannot see it here.
If I haven't, I would like to accept your kind offer.  Hopefully it will solve my problem.
It seems a big coincidence that when I switch  my router of and then back on again the speed is back at 65Mb plus.
Message 12 of 13
I'm sorry to hear this. I've run a test on your line now which is clear. The HG633 is one of our older routers. Would you like us to send a replacement router (Wifi Hub) to see how the connection compares?
