erratic internet connection .
Frank38
Message 12 of 12
For over a week my internet connection has been interupted for periods of an hour or less on a random bassis. My router remains connected to the exchange but shows no internet connection randomly. Line tests have have shown all is well and my home phone connection has been fine . When connected to the internet via my copper to the cabinet line my internet speed and performance of 70 Mbs is normal. My local area ethernet system is performing normally. Very frustating the frequent disruptions to my internet connection whilst trying to get some work done.
Frank
Francis Regan
11 REPLIES 11
Message 1 of 12
A router is on the way for testing.
Message 2 of 12
Please let me have a replacement router to test with. I will return it promptly if unsuccessful
Francis Regan
Message 3 of 12
It may not be relevant but there is a lot of Fibre installation work on-going in my locality, including in the underground duct and pole immediatly outside my home.
Francis Regan
Message 4 of 12
Am now communicating with you on the K88DCEC router which reconnected to the exchange and internet in a short time.
Francis Regan
Message 5 of 12
Hi Chris. Tried a couple of old TalkTalk routers which were in use before you supplied the latest one K88DCEC . The older routers were in use until I switched to Fibre to the Cabinet which gave me my 70Mbs connection. The old routers connected to my Local area network ok but would not connect to the WAN (exchange).
Francis
Francis Regan
Message 6 of 12
I am on a feed to a local cabinet which has been very reliable up to now. Speed is 70Mbs . When internet connection is working normally, which it is at present, it runs at my normal 70Mbs speed and can perform fine for a couple of hours at a time. Then it looses internet connectivity even tho the white light on my router still shows a good exchange connection.
Francis Regan
Message 7 of 12
Do you have another router you can test with?
Message 8 of 12
Router is currently connected to front socket on Box. My connection to exchange is rock solid, and does not drop out at all. Home phone is also fine. Only my ethernet  or wireless INTERNET connection is erratic on my phone, TV and Laptop.
Frank
Francis Regan
Message 9 of 12
Thanks. Line test isn't picking up any issues. Is your router currently connected to your test socket - Your guide to main phone sockets - TalkTalk Help & Support
Frank38
Message 10 of 12
I have updated my profile as requested
Francis Regan
Chris-TalkTalk
Message 11 of 12
Hi Frank38,
  • Name
  • Telephone number
  • Alternative contact number
