on 14-05-2022 06:06 PM
Hi. Since i upgraded my broadband for 150 fibre about 3 months ago i keep having a lot of disconnects every day. They last from 1 to 5minutes. Once it was disconnected for half of the day.
Its connected by wire and i have both talktalk wifi hub 2 and openreach modem. I have no test socket. I am not using telephone line. Firmware seems to be up to date. Tried reseting both router and modem to no avail.
Is there anything else i can do? Is it a problem with stability because of the upgrade or is it faulty device?
Thank you in advance for any help.
on 16-05-2022 08:52 AM
Hi demorell
Would you like me to send a replacement router for testing so we can rule this out?
on 16-05-2022 08:42 AM
Hi. router light is going from white to orange and modem internet light goes off. internet is mostly stable but sometimes it can disconnect 3 times in an hour. yesterday it disconnected at least twice.
on 16-05-2022 08:07 AM
I'm sorry to hear this and I will take a look now. I've run a test on the line which hasn't detected a fault and the connection looks stable for 5 days. Just to confirm, do any of the lights change on the router when the connection drops?
