poor speeds
anoyed
Whizz Kid
Message 26 of 26
is their any chance of getting the DLM reset my speeds have taken a nose dive i used to get 60 mbps download and 20mbps upload at the router after a factory reset and plugged into maintinance socket im lucky if i can get 35mbps download and 6mbps upload also when i go onto the fixit page it tells me my router is dg8041 wrong im running sagemcom53643.00 firmware v sg4k100174 it also tells me im getting 44 at the router when in actual fact 35mbps  and a promised speed of 44mbps yet more porkies I used to be told 60mbps  could yo please make sure no band steering and reset DLM
thank you
dave
25 REPLIES 25
Message 1 of 26
I've sent you another PM, can you please supply the information requested and I'll book the engineer
anoyed
Whizz Kid
Message 2 of 26
all I'm trying to do is get someone to book an engineer to sort the problem but seem to be getting nowhere fast
dave
Message 3 of 26
Sorry no, I'm still waiting for you to send the corrected security information, did you see my PM?
anoyed
Whizz Kid
Message 4 of 26
are we any closer to getting an engineer booked please
dave
Message 5 of 26
Thanks for answering the security questions, I've sent you a PM requesting a little more information
Message 6 of 26
any idea when said engineer might be booked because I've had nothing thank you in advance
dave
Message 7 of 26
Thanks, I've removed the mobile number from your post. Could you answer the security question in the link in my PM and we'll book the engineer for you
Message 8 of 26
yes book the engineer
dave
Message 9 of 26
OK, if you'd like us to book the engineer can you confirm:
  • Confirm your mobile number
Message 10 of 26
yes go ahead and book them their is always someone in then email me
dave
Message 11 of 26
Hi anoyed,
If you'd like us to book an engineer please let us know and we'll confirm some details with you
Message 12 of 26
okay thanks
dave
Message 13 of 26
The only option we have is to arrange an Openreach engineer visit to investigate/resolve the drops in connection and then reset DLM to increase the speed.
Message 14 of 26
it keeps dropping out haven't touched it where our phone line goes to the pole the pole is leaning a bit and the phone line is a bit taunt weather that's what started it off I don't know also doesn't help when BT is always in the cabinets every time they do they stuff somebody's line up
dave
Message 15 of 26
Is the connection dropping or have you rebooted the router?
If DLM is reset and the speed increases then it will drop down again if the connection is still dropping out.
Message 16 of 26
the line may be clear but if the dlm at the exchange witch is at plymstock and is unmanned is stuffed then the speeds will never improve till someone goes and checks
dave
Message 17 of 26
Are all the re connections drops or has the router been rebooted too?
As the line tests are clear then the only option Openreach provide is to arrange an engineer visit to the property.
Message 18 of 26
had them out last time checked everything was fine then rang up the exchange and he was told fault at exchange was fixed then and then the speed immediately increased
dave
Message 19 of 26
Thanks for your reply. The line is in sync at 31mb.
There are a high number of re connections on the line and this will affect the sync speed.
If the connection is dropping with a different router, filter and cable at the test socket then the next step will be an Openreach engineer visit to the property.
Message 20 of 26
25mbps download 5mbps upload
dave
