on 16-03-2025 06:57 PM
Message 41 of 41
I upgraded to full fibre and an eero 6, and have all my devices connected except one. This is a wifi enabled cat flap which was fine on my previous router. However despite trying legacy mode, or disabling 5 ghz it can't see my network and I can't add it using Other. I am in contact with the device's suppliers, but thought it worth asking here if anyone has experienced this or has any ideas? I was also unable to connect it to my laptop via hotspot although the device could see the laptop hotspot and the laptop could see the device.
Answered! Go to Solution.
Labels:
- Labels:
Connection
eero
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
40 REPLIES 40
on 20-03-2025 03:23 PM
Message 1 of 41
It is annoying that most connected devices of that ilk still run only on 2.4GHz in this day and age.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-03-2025 03:20 PM
Message 2 of 41
Hi @Debbie-TalkTalk @Karl-TalkTalk
The signal came up in level today as @CarolineK5 said. However, the 2.4GHz was nowhere near as good as it should have been, with no real interference to speak of. Other locations for the eeros are currently being experimented with. It is annoying that the device in question only works in the 2.4GHz band.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-03-2025 02:05 PM - last edited on 20-03-2025 02:57 PM by KeithFrench
Message 3 of 41
@KeithFrench here are some scenarios so you can see the effect of changes
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-03-2025 11:12 AM - last edited on 20-03-2025 11:22 AM by KeithFrench
Message 4 of 41
Hi @KeithFrench files attached
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-03-2025 09:13 AM
Message 5 of 41
Thank you @KeithFrench I wondered if the app already having the device was causing an issue, but maybe it was environmental and early morning was good for it! I removed the zip file this morning but hopefully you have a copy?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-03-2025 09:00 AM
Message 6 of 41
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-03-2025 08:40 AM
Message 7 of 41
You are very welcome @CarolineK5. I will still look at the trace in a short while and get back to you about it.
I was wondering if you were going to have to do a factory reset on this device to maybe make it forget the WiFi network. Whilst the eero is probably using the same WiFi credentials as the old router, there are parameters such as the BSSID (MAC address of the eero) and the default gateway that change with a new router. However, that was not the case.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-03-2025 06:51 AM
Message 8 of 41
Morning @CarolineK5
I'm so glad to hear that this is now working, thanks for letting us know 🙂
Thanks @KeithFrench for all your help 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-03-2025 06:46 AM
Message 9 of 41
Well this morning I have managed to connect it, via my device is 2.4 only, and other, so it is now working. I don't know why that didn't work yesterday but it is now. Thank you very much @KeithFrench @Debbie-TalkTalk for all your help!
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
19-03-2025 05:17 PM - edited 20-03-2025 06:44 AM
Message 10 of 41
@KeithFrench file is attached will message you
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-03-2025 04:47 PM
Message 11 of 41
thank you @KeithFrench OK will move the eero (it is near the cat flap) then take a trace
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
19-03-2025 04:32 PM - edited 19-03-2025 04:32 PM
Message 12 of 41
Hi @CarolineK5
Ideally, you need to locate the new eero halfway between the first eero & the cat flap. Can you take a fresh WiFi Scanner trace for me, near the cat flap?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-03-2025 04:29 PM
Message 13 of 41
Thank you @Debbie-TalkTalk @KeithFrench unfortunately even though the eero is making the wifi stronger the flap still can't see the wifi. I have done all the previous things, paused 5 ghz, legacy mode etc and still it is not there. I am also in contact with the device manufacturers, but I don't know enough about this to be able to know if this is the eero (likely to be something to do with a mesh network and this device) or the developers need to change something. Any suggestions?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-03-2025 06:49 AM
Message 14 of 41
Hi @CarolineK5
Apologies, please ignore this email, this will have been sent free of charge.
Thanks for your help @KeithFrench
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 17-03-2025 05:47 PM
Message 15 of 41
Thank you I hope so @ferguson
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 17-03-2025 05:39 PM
Message 16 of 41
I believe that is an auto-generated email and can be disregarded, I am sure Karl will confirm.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 17-03-2025 05:31 PM
Message 17 of 41
@Karl-TalkTalk I see I am being charged £89 for the additional eero, is this correct? if I had known this would be necessary I would have kept my previous broadband and router. I have been a customer for nearly 20 years.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 17-03-2025 04:31 PM
Message 18 of 41
You're Welcome 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
17-03-2025 04:12 PM - edited 17-03-2025 04:14 PM
Message 19 of 41
Thank you! @Karl-TalkTalk
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 17-03-2025 04:08 PM
Message 20 of 41
No Problem 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- PC WiFi slow, but devices are OK, (Not a Talktalk problem?!?!). in Broadband
- Logs missing on Router. in Fibre
- Unable to send email from tinyworld.co.uk in Email
- UNABLE TO ACCESS CITYWIRE WEBSITE in Broadband
- TalkTalk email saying my router is no longer supported with software and security updates in Broadband
