Apple devices are connected to eero but no WiFi
Somsrc
Message 10 of 10
We had a power cut two days ago and since then our  Apple devices are struggling to pick up a WiFi signal. They say connected to the network but there’s no internet connection on the device.
All non-apple devices are working fine.
thanks in advance for any help
9 REPLIES 9
Message 1 of 10
Please let us know how you get on and if you need any assistance.
Message 2 of 10
Sounds likely then @Somsrc
Message 3 of 10
OK, let us know how you get on when the new eero arrives.
Somsrc
Message 4 of 10
Thanks both.
Whilst the Apple devices aren’t connecting, there’s a wider issue with the connection as it keeps going down intermittently for non- Apple devices.
i think the issue is the eero router as when I run speed tests on the app it  is showing 150mbps. I’m getting a new one sent out as I think the power cut has done something to it. I’ve done multiple resets of the router and whilst it works for a short time it then becomes temperamental again.
hopefully this fixes the issues.
Message 5 of 10
With this only affecting your Apple products, the issue would appear to be with the iPhones themselves. if the suggestion from@ferguson does not work, try turning each of these off for a couple of minutes & try reconnecting. Ferguson knows much more about iPhones than I do.
Message 6 of 10
Try turning off your iPhone mobile data connection temporarily and see what happens.
Message 7 of 10
Sadly rebooting the eero hasn’t worked.
My iPhone actually connected when I first turned the router back on but then disappeared when I tried to use safari. I’ve included a screenshot showing my phone saying it’s connected but you can see it’s using my 5g phone network
Any other solutions you could recommend?
Somsrc
Message 8 of 10
Hi Keith. I have one eero. When I go on the eero app it says the apple devices are connected and when I got into the WiFi section of my iPhone the WiFi network of my eero has a tick.
It’s strange as every non apple device is connected with no issues.
I’ll turn the eero off for 30 mins and try again.
thanks
Message 9 of 10
How many eeros do you have, what does the app say about the Gateway Eero? If they are struggling to get a WiFi signal, how are they connected? I would first start by turning the eero & ONT off for at least 30 mins & retesting.
