on 09-05-2024 05:14 AM
New customer just completed 10days stabilisation and having problems with devices being kicked of the 5ghz band all onto 2.4ghz and nothing making a difference except factory reset. However this is temporary sometimes it be OK from a few hours to 24hrs then same problem again. Me and father have tried changing every possible setting but the end result is you are unable to connect to the Internet not even 2.4ghz. At times my speed has been 10 or 12 mbps and my package is 250. Can someone advise a fix or should I replace router? My router is the new sagemcom Wi-Fi Hub 2
version SG4K100174. Thanks
on 11-05-2024 11:10 AM
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please they can be difficult to read as text can get out of focus when zoomed in, from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus.
on 11-05-2024 05:08 AM
Thankyou Keith OK I give anything a go what do u advise and what info do u need from me
on 10-05-2024 10:13 PM
The point is, I examine the state of your WiFi & help you set it up to be the best it can be. This not only covers WiFi interference but also signal strength. This will also give a good idea as to why the devices are band steered over to the 2.4GHz band.
on 10-05-2024 10:09 PM
Hi Keith
Thankyou for getting in touch however I don't think it's to do with neighbours as all devices are are being knocked off 5ghz to 2.4 and getting stuck there even at 3am in morning. I'm now factory twice a day to get any device on 5ghz. I've followed all interference advice and dropping connection that talk talk give on here and still nothing. Earlier I connected via LAN my speed was 0.74mbps I'm on the 250 package I don't know what I'm paying for. It's worst than sky when on 80 fibre package
on 10-05-2024 10:03 PM
I've done that and now on wits end I've tried everything and still all devices are being knocked off 5ghz onto 2.4 and can't change this till factory reset I'm now doing 2 reset a day. And my connection earlier using LAN was 0.74mbps like slower than slow
on 10-05-2024 04:22 PM
on 10-05-2024 06:31 AM
Please do not post any personal information on the Community. Please can you add your Account Number to your Community Profile.
on 09-05-2024 07:23 AM
Hi Shazza6788
Please can you add your TalkTalk landline number or account number to your Community Profile, we can then take a look at this for you.
