Disney+ issues on FTTP
on 23-08-2023 07:36 PM
Message 2 of 2
Is anyone else having any issues with Disney+ on TalkTalk. It worked perfectly for years on BT, but since moving to TT full fibre every few days I get an Error 73 - "Disney+ is only available in certain regions. Depending on where you are location, you may not be able to access Disney+"
Disney just tell me not to be connected to a VPN (which im not), and then say that my IP must be being detected as outside the UK - I cant seem to force an IP change by rebooting either the router or the ONT so all I can do is wait hours/days and then it works again (for a few days)
Labels:
- Labels:
Connection
Streaming
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
1 REPLY 1
on 24-08-2023 07:14 AM
Message 1 of 2
Some sites such as netflix, Disney etc use IP geolocation.
Your current IP shows correctly as UK, you can check your IP via https://whatismyipaddress.com/
Disney may need to update their IP info if your IP address shows correctly as UK.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
