Eero 6 limitations
Davew59
Message 8 of 8
I know it’s a previous topic of discussion and unresolved issue regards reduced signal strength experienced when upgrading to Talk Talk full fibre and using the Eero device.
like others I’ve had to install an extender to restore service to some of my device locations. However the extender is  subject to high interference from neighbours devices which are also using Ch1 for 2.4Ghz
I read somewhere the Eero device automatically optimises channel, but this obviously isn’t the case as I have an app where shows a number of networks in proximity also using same Chanel, whilst there are others with no networks.
how do we feed this back to Eero to address this type of limitation along with increasing signal strengths ?
7 REPLIES 7
Message 1 of 8
Hi Dave,
I'm sorry to hear this. Did you purchase the additional eero? Would you like us to send a returns bag?
Davew59
Message 2 of 8
I now have all devices up and running.
ERA were non responsive but accepting the limitation that I am unable to change the channel on the erro devices and signal strengths were lower than previous Talk Talk router, requiring the second erro unit be located nearer to devices
In order to address the resultant high interface from neighbours networks in the vicinity of the second erro unit, I deployed a repeater.
This provides a much higher signal strength allowing me to position in a more practical location, and no longer suffer from Interference.
One downside is reduction in speed when connected via the repeater due to half duplex working, but even this is preferable to have device connectivity issues.
In addition. I also encountered problems finding a compatable repeater due to the Inability to change the 5G channel.from 149, as the T link product for example only works on.lower band
As I result I now have a surplus erro 6 which is not fit for purpose and therefore wish to return to talk talk.
Can you please action this as obviously the full mesh solution previously sold to me is not working.
Rgds
Dave
Message 3 of 8
Good afternoon Dave,
How are you getting on?
Message 4 of 8
I can offer extended WiFi diagnostics in this situation.
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use.
Message 5 of 8
OK thanks. I've checked and signal strength to all devices looks fine. Are you currently experiencing problems?
Davew59
Message 6 of 8
Done
Chris-TalkTalk
Message 7 of 8
Hi Dave,
  • Name
  • Telephone number
  • Alternative contact number
