Eero interfering with laptop USB connections?
on 06-07-2024 08:10 PM
Message 7 of 7
I've had an ongoing problem since joining TalkTalk where my bluetooth speaker would suddenly stop working, which I put down to connecting my laptop to a separate monitor. I never had this problem previously, it only started occurring when I joined and I put it down to the Eero. If I disconnected the monitor, although far from ideal, I could at least get on with things. Since then, the situation has deteriorated and I now lose the internet / wifi connection if I connect anything to my laptop at all (mouse, laptop, bluetooth speaker, monitor, etc.).
Frankly, I am at my wits end. My laptop is completely unusable unless I connect absolutely nothing to it, other than the power cable. My drivers all appear to be up to date, I've tried turning off "Bluetooth Device (Personal Area Network)" under Network Adaptors in Device Manager, which was something I saw mentioned elsewhere that sounded like it had worked as a solution for others with similar issues, all to no avail.
I'm convinced there is some kind of interference / signal clash being caused by the Eero, but have no idea how to resolve this. Any help much appreciated. I am on Windows 10 currently.
Thanks for your time.
Labels:
- Labels:
Connection
Router
Stability
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
6 REPLIES 6
on 07-07-2024 09:54 PM
Message 1 of 7
Thinking about this some more @KingGrimlock how is the internet when you use the eero app? The reason I ask this is because the app communicates with the eero via Bluetooth.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 07-07-2024 04:24 PM
Message 2 of 7
Your WiFi works fine though via the eero, when Bluetooth is disabled, doesn't it. Have you tried rolling back the Bluetooth driver? Which Bluetooth chipset is it (e.g. Intel), have you tried their website for a later driver?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 07-07-2024 04:20 PM
Message 3 of 7
Well, I think the problem is the Eero because that is the only thing in my set up that has changed recently. I don't see what else can have suddenly caused my laptop to have a meltdown every time the bluetooth is switched on when it worked perfectly well before.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 07-07-2024 04:17 PM
Message 4 of 7
Why do you think the problem is with the eero? I said before that it cannot interfere with Bluetooth.
Have you tried contacting the laptop's tech support as the laptop would seem to be the common denominator?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
07-07-2024 04:13 PM - edited 07-07-2024 04:14 PM
Message 5 of 7
Thanks for the reply Keith. Apologies, I tried to be concise and was also suffering from a lack of sleep when I wrote my initial post, so sorry if some of what I said didn't make any sense.
I believe it to be a bluetooth issue, as when I turn bluetooth off on my laptop, I do not receive any issues. So I suspect the Eero and the bluetooth signal are clashing. What muddies the waters (and I'm no expert so this may be completely irrelevant), is that neither the monitor nor the keyboard I attach to my laptop are wireless so I don't quite grasp why having my bluetooth switched on whilst connected to these two items would cause a problem. Especially when they didn't when I was with my previous provider. My bluetooth speaker and mouse are both wireless of course, so that's why I stated USB connection rather than bluetooth connection as the source of the problem.
To try and answer some of your questions - I do not have any wired connections, and yes the internet does appear to drop off completely when the issue arises (either shows as unavailable or, if I am in the middle of downloading something, the download ceases and I have to restart) on the laptop but NOT in the Eero app. I also have a separate work laptop which I switch out, and have had no problems using this. But I don't try running the bluetooth speaker on this, as it's work property so I'm not going to copy personal music files onto it to listen to whilst working (for example). I do connect the screen, keyboard and mouse via a Thinkpad connected into one of the USB ports on it.
You're more than welcome to send me your guide. Always open to optimising my set up and getting the best out of it. If it helps resolve the issue as well, then that's perfect.
Thanks for your time and help with this.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
07-07-2024 02:51 PM - edited 07-07-2024 03:13 PM
Message 6 of 7
There is no way that the eero can interfere with Bluetooth.
Is the laptop connected normally to the Bluetooth speaker? Bluetooth does operate in the 2.4GHz band, but is not the same protocol as used by WiFi, but this does not mean that other 2.4GHz devices (wireless doorbells & mice etc) are not affecting it. As the WiFi is dropping on the laptop, the laptop is the common denominator. Perhaps this needs further investigation & if so you would need to contact the manufacturer's tech support. If the drivers are up to date, this does not mean that there is not a problem with one of them. It may just be a coincidence that the WiFi is going down, which is far more likely to be caused by WiFi interference.
However, other factors should be investigated first. When this happens, what is the status displayed in the app for the internet connection? Do you have any wired connections & if so, how do they perform?
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- Windows XP laptop wi-fi will no longer connect to router in Broadband
- connection message error on iPad. Mobile email and laptop okay in Email
- Having problems with wireless on router in Broadband
- Laptop keeps dropping Talktalk connection or can't see Talktalk network. in Broadband
- Malfunctioning TV box in TV
