Eero pro 6 help
legacy69
Message 3 of 3
Hello everyone received my eero pro 6 today wifi works fine but unfortunately can't connect anything with ethanet. Nothing is found
Yours sincerely
Chris-TalkTalk
Message 1 of 3
Hi legacy69,
How are you getting on, have you tried Keith's suggestion?
Message 2 of 3
Have you tried doing a factory default of the Eero? Eero calls this a hard reset:-
https://support.eero.com/hc/en-us/articles/215473703-How-do-I-reset-my-eero-#:~:text=To%20hard%20res...
