Flashing lights on new router
JohnC61
Message 3 of 3
I've recently upgraded to Full Fibre & supplied with a new modem to accommodate the landline connection.
For the first week, the light remained white.
However, every 23 seconds (yes, I timed it) it cycles through 2 white, 1 orange flashes, 3 times, then goes back to solid white.
I've tried both turning off/on & the 30 seconds reset with no success.
I should point out that my broadband connection doesn't seem to be experiencing any problems but the continual flashing is a concern.
Chris-TalkTalk
Message 1 of 3
Hi John,
How are you getting on, have you tried switching the ONT and router off for at least 30 minutes as Keith advised?
Message 2 of 3
It is not 30 seconds that you need to power things off for, with full fibre you need to power both the ONT & the router off for at least 30 minutes. If that does not change things, do a factory reset of the router's configuration. Try that & if still the same I will ask TalkTalk to investigate it for you.
