Frequent and increasing drops in connection
Frances-
Message 30 of 30
I’m looking for some help with wifi issues that have been ongoing for a few months but are getting increasingly worse.
Issue: My connection seems to keep dropping randomly it started late last year but as it was only for a a few seconds before re-establishing I stupidly ignored it over the past month or two if has been getting much worse while there are periods it is stable for an hour or more there are also periods when I can lose the connection for 5-10 mins at a time multiple times an hour. This is now causing me issues as it drops the connection for online classes, zoom meetings etc.
It is not just with one device this affects my laptop, my desktop my mobile, the PS4 and the TV.
Setup: I have a Sagemcom FAST 5464 router sitting in the hall under the office and less that 15ft away from the TV with no wall in-between
What has been tried:
I have reset the router multiple times (both restarted and factory reset) which seems to improve it a little for a time before starting to drop again.
I have changed the channels for 2.4 and 5GHz in case that helps though the factory resets undoes those. So far it does not prevent the signal dropping out.
I have does line tests, it says it’s fine though the last one, done on Thursday night said in the following up text that there may be an issue with the set up and to contact the tech chat which I did spending an hour on with them on Friday as they talked me through testing the line and resetting the router etc then they sent me a link to work read though the Optimisation guide on the community page though teaching for optimisation only seems to bring up a lot of posts about turning it off. At which point I lost connection for the 4th time in an hour and this time for over 10 minutes. The router itself says it's been fully connected for over 3 days so since the last reset despite my constant "you are no connected to the internet" pages.
Any suggestions of what else I can try?
F
29 REPLIES 29
Message 21 of 30
How are you getting on?
Frances-
Message 22 of 30
Thanks Keith
I'll get a look at that later tonight hopefully and report back asap.
F
Message 24 of 30
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 25 of 30
OK thanks I'll send it to you later tomorrow morning.
Frances-
Message 26 of 30
Yes please Keith. I've tried everyting within my own understanding.
F
Message 27 of 30
Let me know then if you want my help with this. The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Frances-
Message 28 of 30
No wired connections as neither computer has a ethernet connection to use.
The only light on the router is always white and stable, the lights on the openreach socket are stable for Power and PON with the LAN flickering slightly with no changes when from connection up to connection down.
Checking for other networks show 2/3 Sky networks in range but with poor strength which was why I tried out changing the channels used with no success.
Computers, TV and current mobile use the 5GHz connection.
Normally only my camera and my old mobile used as a tablet used the 2.4 band
F
Message 29 of 30
