Full Fibre Upgrade connecting landline
BerkshirePam
Message 13 of 13
I was upgraded to full fibre and was told that I wouldn't have to change my phone and it would work over WiFi. The CityFibre engineers did not connect my phone and now I don't know how to do it.
There doesn't seem to be a phone jack socket on the new full fibre router.
The only phone jack is on the TalkTalk router, but pluging my phone jack into that just stops the router working.
How do I connect my phone to the WiFi please?
12 REPLIES 12
Message 1 of 13
Hi @Dougal361
Please can you create your own topic and we can look into this further for you.
DJI_MINI_3
Super Duper Contributor
Message 2 of 13
Dougal open a new thread the support staff will not answer you in another persons thread.
Dougal361
Message 3 of 13
How do I plug my landline phone into the modem?
Message 4 of 13
Glad to hear that it's now working, just let us know if you need any further assistance
Message 5 of 13
Hi Chris, thanks for your prompts. I have now managed to plug the phone into the back of the router and it seems to work. The RJ11 cable was an extension for the phone. Many thanks!
Message 6 of 13
OK, so how did you connect the telephone to the telephone socket before you upgraded to full fibre?
Message 7 of 13
Yes, I think it's RJ11. It's a  lot smaller
Message 8 of 13
The telephone port on the router is a standard BT port, are you saying that you telephone has a different connector (RJ11)?
Message 9 of 13
I only have a phone jack which doesn't fit into the green port
Message 10 of 13
OK thanks. So when you connect your telephone to the port the telephone is dead and you lose internet connection?
Message 11 of 13
Yes. It was actually covered over by a sticker that says Digital Voice use when instructed.
Chris-TalkTalk
Message 12 of 13
Hi BerkshirePam,
Is the port that you are connecting your telephone too on the router, green?
