on 14-09-2023 03:11 PM
I’m having problems with signal dropping out in a couple of rooms and the ring door bell at the back won’t connect I spoke to someone on live chat for 2 hours yesterday asked me to complete an ip address for the items that drop and said that is now working it’s not I’m on fibre 900 which offers whole home connection does it not ? So why do I have to argue that my current eero isn’t enough
please help
on 17-09-2023 03:19 PM
Don’t confuse the FTTP 900 service and the ability to provide a whole house connection, it’s marketing speak. The FTTP connection has nothing to do with the connectivity within your house, that is entirely down to the router and it’s Wifi capabilities. To be honest it’s extremely unlikely any household would swamp a 900mb service, but great bragging rights I guess.
I sometimes work from home have 25 IoT devices, steaming TVs, music streaming, gaming and multiple computers online and have yet to swamp my 65mb FTTP service.
I don’t have an Eero as I don’t use TT supplied routers, they are too inflexible. I have friends that have the Eero from TT and they struggle with Wifi around the house and they are susceptible to their location. They need to be in clear space, not under shelves or behind furniture. It’s best to add additional nodes to extend coverage or buy a better router. TT might supply a HUB2 as it has better Wifi and more ports.
on 15-09-2023 11:21 AM
I can help further in so much as trying to optimise your WiFi signal if you want. The first thing you may want to check is the location of your Eero.
This is the best router location, but obviously, this is not always practical & a compromise has to be reached.
The general rule is to keep it away from:-
As a very general rule, the signal travels best on the same floor as the router and to the floor below. It does not always propagate very well to a floor above the router. However, with more modern routers, if they have a higher specification, they may be able to get the signal upstairs OK, but your ability to receive it also depends on your device's network adapter being of a higher specification, as well as its age.
on 15-09-2023 05:56 AM
Hi Carlab1
Please can you add your TalkTalk account number or FTTP number to the Private Notes section of your Community Profile, we can then take a look at this for you.
on 14-09-2023 04:38 PM
Hi thanks for the advice, I tried them they just put me through to the tech department and went through the same ip process that I did yesterday - don’t they keep notes on file so you don’t have to do the same thing over and over !
on 14-09-2023 04:03 PM
The problem with the Eero, although only one is supplied, it is designed to work as part of a Mesh network, requiring at least two Eeros. The normal recommendation in this case is to speak to the loyalty dept (direct number 0345 1725157) & tell them one is not enough & can you have another one. Try and see if you can get an acceptable deal with them. If you get nowhere, then come back on here.
