IPhone wifi and Sagemcom router
privateprentice
Message 23 of 23
Hi all,
My iPhone wifi keeps disconnecting from my Sagemcom router. Have replaced the phone recently (from a 12 to a 15) but the problem remains the same. Is this a common problem with a known fix?
Thanks and Regards,
john
22 REPLIES 22
Message 1 of 23
Hi Shirlye88,
Can you please start your own thread/topic and we'll be happy to help
Shirley88
Message 2 of 23
I also have this problem. My iPhone 13 mini keeps disconnecting from sagemcom router. To reconnect I have to turn wifi off and on which is quite annoying. I would be interested in any solution to this problem.
Message 3 of 23
Hi John
Thanks for confirming. This issue is still under investigation with our Devices Team.
Message 4 of 23
Hi Debbie,
Yes it's an iPhone 15 running 17.5.1
John
Message 5 of 23
Hi @privateprentice
Could you please confirm the iOS version for your iphone?
Message 6 of 23
Hi John
I've asked our Devices Team for an update and I will post back here as soon as they come back to me with additional information.
Message 7 of 23
More like run it on the PC near the phone. Just get me all of the stuff again when you next notice the problem.
Message 8 of 23
Yes it was also on my desk, but I might have wandered off... Should I run it again with the phone next to the computer?. There's no pattern to it though - I get failures wherever I am in the house.
John
Message 9 of 23
 @privateprentice
I have just looked at the diagnostics that you have sent me. At the time you captured this information, there was no WiFi interference at all. Your 2.4 & 5GHz bands are the only networks in range of your PC. Your signal strenth of both networks was also OK.
When you did this, was your PC near your phone that has the problems?
Message 10 of 23
Hi @privateprentice
I will try & look at this later today.
Message 11 of 23
Hi Keith,
Wifi.zip Report attached. Sorry for the dealy...  I rebooted my router when I last contacted you and frustratingly it's been better since 🙂
So I don't know whether this will show anything obvious. If you want me to wait 'til problems recur I can do that.
John
Message 12 of 23
Hi privateprentice
Our Devices Team have advised that they are still investigating this issue. As soon as they provide further updates then I will post back on this thread.
Message 13 of 23
Hi John,
So long as the laptop has dual band WiFi, that will be fine (from a technical point of view), just use it near where the phone is having trouble.
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 14 of 23
Hi John
Do you know what fixed the issue last time you experienced this?
Message 15 of 23
Hi Keith!
I have a company windows laptop that I may or may not be able to run an analyser on (no wifi problems with that)... Just FYI, I had this problem in my old house last year too, with a different talktalk router, so it's recurred with different iPhones and routers in two houses.
John
Message 16 of 23
Thanks @KeithFrench
@privateprentice  It would also be worth checking for any interference whilst our Devices Team are investigating.
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.  If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
Message 17 of 23
Hi @privateprentice
Thanks for creating your own thread. TalkTalk is currently unsure if this is a known problem or not. It might be worth a quick check to see what the levels of WiFi interference are like, near the phone.
There is one problem though, iPhones cannot run any WiFi analysers as far as I am aware, what other devices do you have?
Message 18 of 23
Hi John
Perfect thank you 🙂
I've passed this straight over to our Devices Team to take a look.
I will post back here as soon as I have further information.
Thanks again.
Message 19 of 23
Sorry about that. Okay I've added it to my profile
Message 20 of 23
Hi John  @privateprentice
I've edited your post to remove your account number, please can you add this to the telephone number section in your Community Profile.
