Issue with broadband
Catherine29
Message 11 of 11
I got a router on Thursday, it has been set up and I have a solid white light but it says no internet connection when I try to connect. I have now been on to online chat for 3 hours and they keep telling me they need to do some checks but so far that has just been resetting router 3 times and also switching off and back on 3 times also. Anyone got any suggestions on what I can do. I haven't had broadband before on the line. I have recently been moved over from shell but don't want to keep the new Talk Talk contract if it won't work.
10 REPLIES 10
Message 1 of 11
Hi Catherine,
Thanks for confirming 🙂
Message 2 of 11
That's it now, thanks for your help.
Message 3 of 11
You should not need to, just try connecting a device and open a website such as www.google.com etc.
Message 4 of 11
Thanks Karl, should I restart the router again before trying?
Message 5 of 11
I've been taking a look at the connection and noticed the authentication details in the router are incorrect.
I've updated these now and this should work, give the connection a try.
Message 6 of 11
If you could that would be great.
This hasn't worked since I connected it on Thursday. I have a white light but when I try to connect it says no internet.
Message 7 of 11
Would you like me to send you a router for testing ?
Message 8 of 11
I don't have another router to try. I've tried Live chat but I keep getting told someone will look into it and they I get cut off and have to start again  with a new advisor. Is there a tel no I can try?
Message 9 of 11
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault. Do you have an alternative router that you could test with please? Is the voice service working ok?
Message 10 of 11
What device(s) are you trying to connect?
Is it a TalkTalk or Shell router you have been sent?
If TalkTalk I know there is sometimes confusion as to the password to use as there are 2 on the back. One is the admin password to get connected via a web browser that allows changes to the router itself to be made, the other is the WiFi password.
Just double check you are using the correct password. Another thing to check is that it is case sensitive and sometimes there is confusion over similar characters such as letter O and number 0.
You may already have done this, in which case apologies. Staff are back tomorrow and will pick this up.
Do let us know if you are still having issues.
Thank you.
