on 25-04-2024 04:01 PM
Hi gave constant issues with WiFi calling with eero router on full fibre. I have 2 eero 6’s in a mesh. Nearly every call the other person can no longer hear me after 4 or 5 seconds if at all on the call. I have turned off ipv6. I have an iPhone 14 latest version and turned off WiFi assist. I have tried with one router connected and still the same issue. To resolve it I have connected my old TP link router direct which allows successful calls, so the eero routers look to be the issue. Any thoughts on what to do
on 01-09-2025 09:26 AM
Hi there @Laughingjester, please start your own thread so we're able to assist you. Thanks
on 01-09-2025 09:23 AM
Is this a fix for WiFi calling disconnections on eero 6 ?
on 27-02-2025 08:35 AM
Hi Paulcostello24
Please can you create your own topic on the Community, we can then take a look at this for you.
on 26-02-2025 06:03 PM
To save time open your own thread the support staff will not answer your questions in another customers thread.
on 26-02-2025 03:08 PM
I have the same issues on both iPhone 14 & 15, it's almost if the eero routers are trying to swap you to nearest mesh unit with strongest signal but been really bad today for some reason.
im already using the google dns settings as well, tried cloudflare dns and same problems.
on 24-05-2024 06:35 AM
Hi Andy,
I've fed this straight back to the team now. I'm really sorry that we couldn't resolve this in the first instance for you. Is everything now working ok for you?
on 23-05-2024 04:56 PM
Hi i got fed of waiting and contacted Eero direct who gave me a response in 2 days and a solution. I would have throught Talk Talk with the number of units they had purchased would have some form of preferential support.
This was the solution for the record which may be useful to add into your KB
In the meantime, I kindly request your assistance in updating your DNS settings. To ensure a seamless process, please follow the steps outlined below:
Once completed, proceed with changing the DNS settings by following these instructions:
Please note that this action will result in a reboot of your network to propagate the new settings across your devices.
Thank you for your cooperation in this matter. Should you encounter any difficulties or require further assistance, please do not hesitate to reach out
on 22-05-2024 11:52 AM
Hi Andy,
I've been asked if you could try the wifi calling again please and if the same issue is still happening then could you make a note of the date and time that this happens exactly as we need to re-check the logs to see what is happening on our side.
on 14-05-2024 08:44 AM
Hi Andy,
I'm still here and chasing this daily. Our Devices Manager also is chasing this with eero directly.
on 10-05-2024 06:09 AM
Hi Andy,
I'm really sorry about this. I will continue to chase this until we know more back from eero.
on 09-05-2024 03:38 PM
I’m not impressed with the response on this, it’s almost 2 weeks now. I’m fortunate that I have my old routers still
on 09-05-2024 08:05 AM
Morning Andy,
I've not forgotten your post and I'm still chasing this for an update for you.
on 03-05-2024 06:18 AM
Hi Andy,
Apologies for the delay. I spoke with our Devices Manager yesterday afternoon and he advised that eero are still investigating this. He has chased this for an update and will let me know as soon as they come back to him.
on 02-05-2024 05:54 PM
Is there any update on this please
on 30-04-2024 12:04 PM
Hi Andy,
Not at the moment thank you 🙂
on 30-04-2024 11:23 AM
Thank you for the update, do they need any other information
on 30-04-2024 09:17 AM
Morning Andy,
Our Devices Manager has advised that eero are still investigating this so I should hopefully know more over the next few days.
on 30-04-2024 07:10 AM
Hi Andy,
I'm sorry for the delay. I've chased this for an update with the team now.
on 26-04-2024 10:02 AM
Thanks for the additional info Andy. Our Devices Manager is taking a look now and will also raise it with eero.
Michelle 🙂
on 26-04-2024 09:35 AM
Update on this,
1. Wifi Calling works at other houses including one with Talk talk and an Eero router
2. It works fine at my own house since i have swapped out the two EERo routers for TP-Link routers set up in a mesh system
3. From what i can see the Eero routers have the latest software
