Issues with Eero router for WiFi calling
Andydav66
Message 24 of 24
Hi gave constant issues with WiFi calling with eero router on full fibre.  I have 2 eero 6’s in a mesh.  Nearly every call the other person can no longer hear me after 4 or 5 seconds if at all on the call.  I have turned off ipv6. I have an iPhone 14 latest version and turned off WiFi assist.   I have tried with one router connected and still the same issue.  To resolve it I have connected my old TP link router direct which allows successful calls, so the eero routers look to be the issue.  Any thoughts on what to do
23 REPLIES 23
Message 1 of 24
Hi there @Laughingjester, please start your own thread so we're able to assist you. Thanks
Message 2 of 24
Is this a fix for WiFi calling disconnections on eero 6 ?
Message 3 of 24
Hi Paulcostello24
Please can you create your own topic on the Community, we can then take a look at this for you.
Message 4 of 24
@Paulcostello24
To save time open your own thread the support staff will not answer your questions in another customers thread.
Paulcostello24
Message 5 of 24
I have the same issues on both iPhone 14 & 15, it's almost if the eero routers are trying to swap you to nearest mesh unit with strongest signal but been really bad today for some reason.
im already using the google dns settings as well, tried cloudflare dns and same problems.
Message 6 of 24
Hi Andy,
I've fed this straight back to the team now. I'm really sorry that we couldn't resolve this in the first instance for you. Is everything now working ok for you?
Andydav66
Message 7 of 24
Hi i got fed of waiting and contacted Eero direct who gave me a response in 2 days and a solution.   I would have throught Talk Talk with the number of units they had purchased would have some form of preferential support.
This was the solution for the record which may be useful to add into your KB
In the meantime, I kindly request your assistance in updating your DNS settings. To ensure a seamless process, please follow the steps outlined below:
  1. Open the eero app on your mobile device.
  2. Navigate to the "Discover" tab.
  3. Toggle off the "Advanced Security" feature to temporarily disable them.
Once completed, proceed with changing the DNS settings by following these instructions:
  1. Tap on "Settings" (located in the bottom right corner).
  2. Select "Network Settings."
  3. Tap on "DNS."
  4. Choose "Custom DNS" from the options provided.
  5. For IPv4 Primary, enter "8.8.8.8"
  6. For IPv4 Secondary, enter "8.8.4.4"
  7. Tap "Save" in the top right corner of the screen to apply the changes.
Please note that this action will result in a reboot of your network to propagate the new settings across your devices.
Thank you for your cooperation in this matter. Should you encounter any difficulties or require further assistance, please do not hesitate to reach out
Message 8 of 24
Hi Andy,
I've been asked if you could try the wifi calling again please and if the same issue is still happening then could you make a note of the date and time that this happens exactly as we need to re-check the logs to see what is happening on our side.
Message 9 of 24
Hi Andy,
I'm still here and chasing this daily. Our Devices Manager also is chasing this with eero directly.
Message 10 of 24
Hi Andy,
I'm really sorry about this. I will continue to chase this until we know more back from eero.
Andydav66
Message 11 of 24
I’m not impressed with the response on this, it’s almost 2 weeks now.  I’m fortunate that I have my old routers still
Message 12 of 24
Morning Andy,
I've not forgotten your post and I'm still chasing this for an update for you.
Message 13 of 24
Hi Andy,
Apologies for the delay. I spoke with our Devices Manager yesterday afternoon and he advised that eero are still investigating this. He has chased this for an update and will let me know as soon as they come back to him.
Andydav66
Message 14 of 24
Is there any update on this please
Message 15 of 24
Hi Andy,
Not at the moment thank you 🙂
Andydav66
Message 16 of 24
Thank you for the update, do they need any other information
Message 17 of 24
Morning Andy,
Our Devices Manager has advised that eero are still investigating this so I should hopefully know more over the next few days.
Message 18 of 24
Hi Andy,
I'm sorry for the delay. I've chased this for an update with the team now.
Message 19 of 24
Thanks for the additional info Andy. Our Devices Manager is taking a look now and will also raise it with eero.
Michelle 🙂
Andydav66
Message 20 of 24
Update on this,
1. Wifi Calling works at other houses including one with Talk talk and an Eero router
2. It works fine at my own house since i have swapped out the two EERo routers for TP-Link routers set up in a mesh system
3.  From what i can see the Eero routers have the latest software
