on 12-05-2024 12:35 PM - last edited on 21-08-2024 07:26 PM by fr8ys
Surely someone can help me on this. Hours spent on the phone and on the online chat bots.
Talk Talk engineer booked to come out to me, he turns up, he is an independent engineer who hasn't a clue about the Eero boxes and totally wasted 2 hours of my life.
2 hours on the phone to SUPPORT wow!!! After 35 minutes of going through all the information being transferred 3 times to different people. Explaining about the lights on the Eero and the Fibre box to be asked, can I make sure they have been switched on. If you are going to employ people from a call centre please please train them.
2 hours on the phone I explained I had tried 5 different Eero units and I was not told that there is a router Eero which I should have. The engineer turned up with one he didn't know it was a router box????
Still no connection. Still annoyed...
Sky worked up until midnight on the 9th. My connection with Talk talk "Went live!!!!!!" on the 3rd, I tried then and was advised wait until your sky connection switches off and it will be ok.
Funny enough just a staling tactic. Sky switched off, Talk Talk still not connecting, still the same error. Where the Eero cannot be assigned a WAN address. Surely this is a simple fix. Your servers are not releasing an IP address to the Eero here.
Can some one with some knowledge please respond to me.
on 15-05-2024 12:18 PM
Hi Gary,
Apologies for the delay, I'll chase it up and get back to you when I have an update
on 14-05-2024 04:17 PM
Hi Chris
Still no update at this end, ,is there anyway I can contact them or you can ask them to update me please?
many thanks
Gary
on 14-05-2024 11:36 AM
Hi Gary,
It's been assigned to one of our network guys to take a look at so hopefully we'll hear something further soon
on 14-05-2024 11:28 AM
Good morning Chris, I've just checked and still no connection here.
I haven't heard anything from the Future Fibre team in form of an update.
Have you any updates please
many thanks
Gary
on 13-05-2024 02:11 PM
No problem Gary 🙂
on 13-05-2024 02:08 PM
Thank you so much for your help. I do wish that someone would have pointed me here right form the start as at least you seem to know what you are talking about and not just concentrating on if I had plugged my box in.
Thank you again
lets hope they can sort this out for me and maybe OpenReach can just assign one number to each address separately which would stop all these issues.
many thanks
Gary
on 13-05-2024 02:06 PM
OK thanks, I'll pass it over to our Future Fibre team and ask them to take a look, I'll let you know when I receive an update or they may contact you directly
on 13-05-2024 01:44 PM
The Fibre to post was installed at the same time.
My connection was installed first then when they moved in there's was installed.
There has always been confusion around these ONT's but we was assured that the number were 933 for me and 631 for them, but by the sound of it, they are the other way around
on 13-05-2024 01:40 PM
Where both ONT's installed at the same time?
on 13-05-2024 01:39 PM
Yes the ONT I am connected to is another separate address and they are connected to BT.
My address is separate
on 13-05-2024 01:37 PM
OK, it's still showing the ONT is on so if your ONT is off then it must be showing the other ONT, on your account. So just to confirm, the ONT that you are currently connected to is with BT not TalkTalk?
on 13-05-2024 01:12 PM
OK thanks, I'll check it now and get back to you
Hi Chris
Ok mine is now switched off.
on 13-05-2024 01:10 PM
Can you switch your ONT off and let me know when you've done this, and I'll check the line
on 13-05-2024 01:06 PM
There has been confusion ever since Full Fibre was installed at the properties 3-4 years ago.
There is no number on either of our OpenReach boxes.
There are two ONT numbers at this property one ending in 933 and one ending in 631.
At the moment I am connected to their BT connection posting this. Which you say you are connected to.
I have the serial number of both fibre boxes in the house if that helps any more?
I had an open reach engineer out to my property on Saturday I would have hoped he had checked the ONT numbers where correct coming into my property but he seemed to not be very well trained and hadn't a clue how any of your connection worked which was very worrying
on 13-05-2024 12:57 PM
If their ONT is with BT I won't be able to connect to it. Just to confirm, does the ONT in your home have the serial number ending 933?
on 13-05-2024 12:53 PM
Ok so I have another number.
Where shall I post that?
Sounds like there has been confusion as to which ONT is to which address.
My fibre box is not connected so you must be connected to the other property.
They are on BT if you switch connection from that box to mine will they loose their connection?
on 13-05-2024 11:19 AM
OK thanks. The last 3 digits on the ONT are 933, The IP address of the router connected to this ONT is the same as the IP address that you are posting from.
on 13-05-2024 11:07 AM
No they are with BT a completely separate house and account. For some unknown reason there is always confusion with the two properties.
I have explained this when I took the account and also numerous times to your support on the phone
The account number here is mine and mine only.
Can you confirm the last 3 digits of the ONT my account is connected to please
on 13-05-2024 11:05 AM
Are both lines on the same account number, the one you've entered in your profile?
