on 21-10-2024 11:52 AM
I signed up for a new fibre service and was sent an Eero router. It only has 2 ethernet ports, and from what I can see one will be taken up by the digital phone adapter and the other the ONT.
Is there any way of swapping this router out for something that has a digital phone port incorporated into the router (like others do), and some extra ethernet ports? I require 2 spare ports for my own networks. Furthermore, I really don't like having so many boxes plugged in (ONT, ROUTER, DV etc) when it can all be incorporated into one. I don't want to have to go out and purchase extra equipment to give me the ethernet ports I had before either.
I don't doubt the Eero might be a good router but i'd rather have an all in one device - can you advise please?
Since the Openreach/Kelly engineer decided not to show up to my appointment, I now have another month to sort this out, but I am considering going with another provider..
on 21-10-2024 04:12 PM
Hi @Chris3210
Just make sure that it is a Gigabit switch. This is not a recommendation, but an example:-
on 21-10-2024 01:08 PM
A four port switch is quite cheap these days, and would connect to one of the ethernet ports of the EERO so that other devices can connect.
on 21-10-2024 01:04 PM
Thanks Karl, so there is no option via TalkTalk to now swap with another device? I should have done more research but I really wasn't expecting to fill a whole table full of devices for this.
If I did get a switch, would the uplink come from the ONT? or does the uplink come from the Eero and then plug the DV into the switch?
on 21-10-2024 12:12 PM
With a package that specifically has an EERO supplied, our system does not have the option to send a different router, this option is not shown, so we only have the option to order or replace an EERO like for like.
A switch can be used to give more ports when connected to the eero.
