New eero 6
silvergirl
Super Duper Contributor
Message 30 of 30
Hi, I have received an eero 6 with instructions on how to get the app. What I don't have is the Grandstream component to be able use my phone. Will that be sent to me soon please?
Silvergirl
29 REPLIES 29
Message 21 of 30
Hi Silvergirl,
I can confirm that you are on the correct profile but if you experience any problems please let us know
Message 22 of 30
I am not even sure what that means? The Grandstream should be preconfigured to link with the eero on your TalkTalk connection and if you follow the instructions it should just work. Mine did.
silvergirl
Message 23 of 30
Thank you, I have received the Grandstream today. Please could you confirm that I have Profile T?
I do not want to install anything until I am sure everything is correct.
Silvergirl
Message 24 of 30
Hi silvergirl,
I've ordered the DVA, it should be with you within a couple of working days
Message 25 of 30
This has been flagged up for you, nothing more to do, just sit back and wait until the support team respond. 🙂
silvergirl
Message 26 of 30
Yes, I have a Hub2 with voice port. I would like to switch to the eero. I will wait for someone pick this up on Monday - please let me know if I need to make contact again.
Silvergirl
Message 27 of 30
Ah, OK, did you previously use the Hub 2 with the phone connected to the voice port? You can continue to use that if you wish. Or if you prefer to switch to the eero with DVA then the support team here can sort this out for you when they are back online from Monday.
silvergirl
Message 28 of 30
Hi, thank you for the quick reply. I already have the Full Fibre package and I did not order the eero, it was sent to me but without the VoIP part. I thought it was probably because I have just renewed my contract.
Silvergirl
Message 29 of 30
I presume you did order a Full Fibre with VoIP package, when is the go live date?
