New router eero 6
on 22-11-2024 11:52 AM
Message 18 of 18
As part of my renewed contract I was offered a new router eero 6 that replaced my sagem one which worked efficiently with my full fibre service. I believed that the eero 6 would provide a faster service but unfortunately it only had two rj45 connections. I needed a digital voice adapter for my phone and because I also use a Hive heating control I had to buy a 4 way ethernet switch. The DVA had to be requested separately which took nearly an hour on the phone. I have yet to check whether I have been charged for delivery. The last straw is that the eero 6 will not connect to my ONT box. I am not the first Talktalk customer to have this problem. Does anyone know how this problem can be solved? In the meantime I will continue with my Sagem device!
Chris G
Labels:
- Labels:
@talktalk.net
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
17 REPLIES 17
on 12-12-2024 08:18 AM
Message 1 of 18
Ingram process returns for TalkTalk, so you can use the returns bag for the equipment.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 12-12-2024 08:09 AM
Message 2 of 18
Would you please confirm that I should send the eero 6 and the DVA to "Ingram Returns". I have a suitable bag and label.
Chris G
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-12-2024 08:22 AM
Message 3 of 18
Ok no problem. Thanks for letting me know.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-12-2024 08:13 AM
Message 4 of 18
My Sagemcom router is fine and always has been since I first received full fibre. I believed, wrongly, that the eero 6 would be better. That and the DVA will be returned today.
Chris G
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-12-2024 07:28 AM
Message 5 of 18
I'm really sorry to hear this. Is your connection still ok since the Sagemcom router has been connected?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-12-2024 03:51 PM
Message 6 of 18
Thank you for taking the time to give such a detailed response. I think I was aware of some of the issues you raise, but I am severely constrained by the availability of electrical sockets, doorways and floor coverings. This morning however was the last straw with the eero 6. When I came down for breakfast the light on the device was showing red, ie no connection to the internet. I tried the power down/up reset but that didn't work. It just flashed white. Because of other commitments, I needed the internet to work so I resorted to my faithful Sagemcom. Instant success. I have had three weeks of grief with this eero 6 and tomorrow it is being returned along with the DVA.
Chris G
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 09-12-2024 03:19 PM
Message 7 of 18
Hi @Canalman
Sorry for the length of this post.
One eero on its own is unlikely to provide satisfactory coverage, a second one is often required to operate in a mesh to resolve this issue. However, it is impossible to say if that is the case without you helping me to do an investigation (I do not charge for this - it is free to any TalkTalk customer) of your WiFi network. Where the eero is concerned, its location is everything, so this is probably the first place to start.
These are my recommendations for the best locations for a router, extender mesh nodes and your devices, but obviously, this is not always practical, and a compromise has to be reached. Where Full Fibre is concerned, the router connected to the ONT can easily be moved to a better location via a longer Cat 6 minimum, Ethernet cable.
The general rule is do not keep them in a cupboard, but out in the open and sited as high & centrally within the property. Keep them away from:-
- Cordless phone (DECT) base stations
- TVs
- Loudspeakers & any sub-woofers (including those used with a PC)
- Computer monitors
- Electrical appliances – they often transmit their own signals that can interfere with Wi-Fi signals.
- Bluetooth devices – they operate on the same Wi-Fi frequency as your broadband, which can cause signal problems.
- Mirrors – they actually reflect Wi-Fi signals, stopping them from passing through walls and reflecting them back into the room.
- Anything containing large amounts of water – things like fish tanks and boilers can absorb Wi-Fi signals like a sponge.
- Large metal objects – radiators, for instance, will have the same effect on your Wi-Fi as mirrors. If you have a tower PC case with an internal WiFi card, the metal of the case can block signals to & from the antennae if they are located behind the tower case.
- Glass - different types of glass can cause problems for Wi-Fi signals to pass through:-
a) Thick window glass or glazing can block Wi-Fi signals.
b) Low-emissivity (Low-E) windows have a metallic film that can reflect and block Wi-Fi signals more than clear glass.
c) Tinted glass often has a metallic film that can interfere with radio signals.
d) K glass double glazing has a metal vapour coating that can reduce Wi-Fi signal strength by 30-50%.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 09-12-2024 03:11 PM
Message 8 of 18
Thanks for the advice about profiles. My eero 6 now connects to the internet but its performance is no better than the Sagemcom router and it requires additional hardware to clutter my hallway.
Chris G
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 09-12-2024 08:37 AM
Message 9 of 18
Hi Canalman,
I've requested the profile change, this should complete within about an hour
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 07-12-2024 08:48 AM
Message 10 of 18
I'll re-escalate this for you, @Canalman. Staff won't be back on here before Monday, though.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 07-12-2024 08:24 AM
Message 11 of 18
Please advise when my profile has been changed. I would like to be able to prove my eero 6 is working.
Chris G
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-12-2024 02:46 PM
Message 12 of 18
Yes please. If I or Talktalk's technical team had understood the issue of profile with Cityfibre, then I would not have wasted the last two weeks. I will also pass on the advice to eero.
Chris G
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-12-2024 09:09 AM
Message 13 of 18
Hi Canalman,
You are on the wrong profile, would you like me to change it now?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 02-12-2024 09:41 AM
Message 14 of 18
It all depends which profile you are on. Profile T is what you want which will allow both the Sagemcom & eero to work.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 02-12-2024 08:41 AM
Message 15 of 18
Community profile fully completed after much searching in the maze. I am with City Fibre but the previous router, Sagem, worked first time straight out of the box.
Chris G
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 01-12-2024 10:22 PM
Message 16 of 18
Hi @Canalman
Does CityFibre provide your Full Fibre, if it is, TalkTalk will need to check the fibre profile, otherwise it will not connect at all. Please update your Community Profile as requested by @Anonymous
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 22-11-2024 01:04 PM
Message 17 of 18
- Name
- Telephone number or Account number
- Alternative contact number
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
