Monday
I’ve had no problems with my connection for about 10 months. The connection dropped this morning with a red light on my eero router. PON light was flashing. I powered both off for a good few minutes before powering them back on. Still nothing.
I spoke at length to webchat. After trying a different cable and powering down, the chap said that they’d send a new router. I explained that I was not convinced that the router was the problem because a flashing PON is often an authentication failure. He explained that the diagnostics were certain of the problem, and he assured me that a new router would solve the issue.
I work from home, so 3 days without a connection is a nightmare for me.
I have an identical eero as an extender, so I factory reset that and went through the eero app to replace the old gateway with this “new” eero. Going through the process was fine until it tried to connect to the internet – same problem as the other one. While it’s possible that both routers failed with the same error on the same day, it’s unlikely. This suggests that it’s not the router at fault, but occurs somewhere between the ONT and the network, with authentication being a likely candidate.
Some googling suggests a serial number mismatch, which would be weird given the 10 months of normal service. Any tips on getting support to double check the serial number authentication with OpenReach?
55 minutes ago
Hello again. Still no contact and I really need this to be sorted. The PON light is still flashing even without the router plugged in, so it’s definitely a connection or auth problem. Please could this be escalated further and expedited?
thanks
James
5 hours ago
Thanks Michelle, I really appreciate it.
5 hours ago
I'm really sorry. I've chased the team now and have asked them to provide an update ASAP. I'll post back here as soon as they reply.
yesterday
Hi @Chris-TalkTalk. Nobody has been in contact and the issue persists. I’ve just power cycled the router and ONT and it’s the same as it’s been since Monday.
I suspect the automated text message was in relation to a new router being dispatched. I’m fairly certain this won’t solve the problem, so I guess I’ll have to start from scratch tomorrow?
This is really disappointing.
yesterday
Hi @Chris-TalkTalk. No, although I did receive a text saying “Good news! We’ve applied a solution”.
I can’t verify this as I’m not at home (although I can’t reach the router via the eero app like I usually can). I’ll reboot the router when I get home later.
James.
yesterday
Hi James,
Just checking in with you, has anyone been in contact yet?
yesterday
Hi @Michelle-TalkTalk . I’ve not heard anything this morning. I’d be very grateful for anything you can do make this happen.
Thanks,
James
yesterday
I received confirmation that this was passed to a colleague in the Faults Escalation Team yesterday. If you're not contacted by this morning then please let me know and I can chase this for you.
Tuesday
Tuesday
I'm sorry to hear this. I've escalated this over to our Faults Escalation Team now and I will let you know as soon as I receive an update back. It's possible that our team may also try and contact you directly.
Monday
If you would like the support team here to look into this for you make sure that your personal details including TalkTalk phone number or account number are complete on your community profile (click here) so that they can link your forum identity with your account and then wait for them to respond.
Monday
Staff will respond during the day, @Clem-Fandango.
Please complete your community forum profile details for them to identify your account. Add your Talktalk phone number or account number by going via your avatar; settings; drop down menu...complete Personal Information. SAVE CHANGES.
