No landline pone since switching to Eero
Parkside1
Message 29 of 29
Had eero set up at home, yesterday. Internet and Wi-Fi working fine. Have connected our phone to the adapter via the connector provided, as per the instructions. There still isn't a blue status light showing for the phone on the adapter. The power and internet blue lights are lit. We can't make or receive calls on it.
28 REPLIES 28
Message 21 of 29
Hi Parkside1,
Is the line completely dead?
Message 22 of 29
Updated profile.
Message 23 of 29
Yes. Tried that.
Message 24 of 29
Apologies for the confusion. The below FTTP box.
Fibre Connection Box lights guide - TalkTalk Help & Support
Message 25 of 29
Sorry., what's the ONT?
Message 26 of 29
Thanks. Did you also try powering down the ONT too?
  • Name
  • Telephone number
  • Alternative contact number
Message 27 of 29
Hi Michelle
We've tried this twice, now and it's still the same. Two blue lights for power and internet. Nothing for phone.
Message 28 of 29
Thanks for your post and I'm sorry to hear this. Could you try the below please.
RESETTING YOUR DIGITAL VOICE ADAPTER
If your Digital Voice adapter or router has stopped working, we may ask you to reset it to check everything's working as intended. To do this:
  1. Insert a pin or straightened paper clip into the hole labelled “Reset” on your Digital Voice adapter.
  2. Slightly push and hold it in for up to 20 seconds; or until all the lights, apart from the power light, switch off. Once this happens release the reset button.
Factory reset of the device will take a full 15 minutes and you need to wait until the allotted time has passed for the full factory reset to be completed. After 15 minutes, check your Digital Voice adapter device and try to re-test to check if the issue resolved.
