No white light on router but internet works ok
TrixieRa
Message 9 of 9
For sometime now the white light does not work on my GD8041W, but the starting up process does light up.
I called and reported it, and after spending a long time going through tests (most of which I had already done), I was told that as long as it still worked, they would not replace it!
That is so annoying, as it's such a simple thing, and it's reassuring to have that light, but why is it denied?
Has anybody else had that problem?
8 REPLIES 8
Message 1 of 9
Hi AdilJ1
Please can you create a new topic on the Community, we can then take a look at this for you.
Message 2 of 9
If you need further help, @AdilJ1, please start your own topic and staff will reply during the week.
You'll also need to complete your community forum profile details for TT staff to identify your account.
AdilJ1
Message 3 of 9
I seem to have the same problem, although going through the diagnostics was difficult on a phone and terminated early with a survey which I responded to appropriately.  I still have no white light on the router but internet access seems OK.
Message 4 of 9
Hi @TrixieRa
That's great, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
TrixieRa
Message 5 of 9
Thanks Debbie,
The replacement arrived today and was working within 15 mins.
I will send the faulty one back within the next day or two.
Again, thanks for your prompt help and support.
regards
TR
Message 6 of 9
Hi TrixieRa
Apologies for this.
The replacement router is on its way and a returns bag for your current one.
Please allow 24-48hrs for this to arrive. Let us know how you get on.
TrixieRa
Message 7 of 9
Yes please Debbie,
At last you have understood and solved the problem.
I was told it was not a fault and I would have to pay!
Thanks again.
Message 8 of 9
Hi TrixieRa
This will be a fault with the router, would you like me to send a replacement router?
