4 hours ago
I have just been upgraded to full fibre - cityfibre came out and did theworks. They installed a new aerial cable from the nearest wooden telegraph pole.
They did not remove the old BT copper aerial cable. Therefore I now have 2 aerial cables from the telegraph pole to my house - the old BT one is no longer in use. Who should I contact to get it removed? Should Cityfibre have removed it? thanks
4 hours ago
Hi pclayto3,
If you'd like the drop wire removing (City Fibre won't as it's not their property) you could try contacting Openreach directly - Report damage, vandalism or a health & safety issue | Openreach
