Power line adapters
NeilMcC
Message 12 of 12
My power line adapter has no lights, could this be causing my lack of internet. I have a new wi do hub router, all connections are ok but amber flashing light!
Also how do I get replacement talk talk adapters? Thanks.
11 REPLIES 11
Message 1 of 12
Hi Neil,
the adapters were dispatched on Saturday, so are on the way to you.
Message 2 of 12
You're Welcome 🙂
Message 3 of 12
Wow thanks Karl, that is amazing service.
Message 4 of 12
I've also sent a quick survey to you via PM.
Message 5 of 12
A set of adapters are on the way to you.
Message 6 of 12
Profile updated.
Message 7 of 12
  • Name
  • Telephone number
  • Alternative contact number
NeilMcC
Message 8 of 12
Thanks, I have an engineer appointment booked for next week but want to problem solve as much as possible so that it isn’t something that I am or not doing?
Message 9 of 12
Then that is not the cause of the orange flashing light on the router. I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
NeilMcC
Message 10 of 12
One of them where the TV is works fine, the other that would usually be connected via yellow Ethernet cable to the router, displays no lights. I have tried in other power plugs but same result.
Purchased them from Talk Talk, maybe 5 years ago, Huwawei is the brand.
Message 11 of 12
Are the PLAs on the WAN port of the router then? What happens if you try them in different power outlets?
Which make/model of PLA do you have, where were they purchased within TalkTalk & roughly how long ago was this?
