25-06-2023 10:32 PM - edited 26-06-2023 11:13 PM
I've had to recently restart/reset the router several times, but in doing so, optimization mode has been reenabled. I don't think the router can handle optimization mode properly. Can I please have it disabled again?
Will disabling Wi-fi 'Bandsteering & Roaming' achieve the same result?
Bill
on 30-06-2023 06:31 AM
OK, just let us know if you need any further assistance
on 29-06-2023 04:51 PM
Hi @Anonymous
I think optimization is now off.
Everything OK.
Bill
on 27-06-2023 12:04 PM
I'm sorry to hear this. Would you like us to switch this off again?
27-06-2023 11:57 AM - edited 27-06-2023 12:09 PM
I've just restarted the router, NOT reset to factory settings, but the router still chose to set its own wireless channels. So it looks like I should try to avoid restarting the the router. Besides, for many other settings the router gets very confused when something is changed, and blanks out what should be on the screen.
Sometimes, it throws its toys out of the pram, and closes the user's web interface, for no reason. Not very stable router.
When the web interface is restarted, everything is OK. Very inconvenient.
Bill
on 27-06-2023 10:27 AM
Hi Billx
No problem 🙂
on 27-06-2023 10:22 AM
Thanks @Debbie-TalkTalk
on 27-06-2023 07:10 AM
Hi Bill
I've now switched the WIFI optimisation off.
on 26-06-2023 11:01 PM
The router was reset/restarted several times yesterday. It's running normally since then, and has been continually on since then.
Bill
on 26-06-2023 06:27 AM
Hi Bill
Sorry for the delay. Is your router currently switched off?
