Router didn't arrive
Hindzia_0
Message 6 of 6
Two weeks ago (28.07.2023) i confirm order to upgrade Fibre 65 to Full Fibre... Tomorrow 11.08.2023 i have appointment with engineer to install wire and other stuff... but router never arrived.
I see a lot of customer have this problem...
Maybe its time to make some noise about this problem in social media.
5 REPLIES 5
Message 1 of 6
We currently only supply the wifi hub router that you are using at the moment and do not have any other models available.
Hindzia_0
Message 2 of 6
I read and waited for the package. Every time I increased my connection speed I got a new router.
 Its, much better if i  dont must change my router.
Message 3 of 6
If you have the Wifi Hub router then this will work with the FTTP connection. Were you advised that you would receive a different router?
Hindzia_0
Message 4 of 6
Yes i sitll use my old Fibre 65 connection and router
Message 5 of 6
Thanks for your post. Can I just confirm, are you currently using a Wifi Hub router with your current connection?
